Pietenpol-List: Avionics package
made some ebay purchases.... scored an altimeter from the 40's and a tach and an airspeed indicator that were supposed to be for a tiger moth...new in boxes.. the airspeed indicator has a 1931 manufacture date.. they lookreally groovy18 ribs done since nov 1stpicked up wood for the longerons today and tore down the A engine.. makin sawdust in louisvilleJeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/gaug ... ______Date: Thu, 11 Nov 2010 16:58:20 -0800 (PST)
Re: Pietenpol-List: Avionics package
Tim...checked it out this morning and its even straight!All fingers and thumbs accounted for!Scotty [Laughing]--------ScottyTamworth, AustraliaBuilding a Corvair Powered Pietenpol Air Camperwww.scottyspietenpol.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Avionics package
Original Posted By: bender
Hi Jeff,Pictures please? I love this stuff.Dan HelsperPoplar Grove, IL.-----Original Message-----
Pietenpol-List: Re: Avionics package
Original Posted By: "bender"
If you are big and tall,I'd think about making the rear cockpit longer,like thelong fuselage drawings or a bit more.I'm 5-9 built the long fuselage and thereisn't much room for my skinny self.dave--------Building a PietRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Avionics package
yup.... it reads in tens of knots... from 20 to 120 on the outer scale then upto 195 on the inner scale as it goes around again..i can't believe these are NOS..the boxes are even cooljeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/spee ... ______Date: Fri, 12 Nov 2010 10:59:09 -0600
Tom,As a rule, edge welding two smaller thicknesses to obtain one thicker finishedpiece does not equal the strength of a solid piece. The only place the two piecesare joined is at the outside edges, so, in bending, the resulting piece isweaker than a solid piece. This would be like making a sheet of plywood, butonly gluing the layers together at the outside edges, with no glue in the middle.Now, if the part will ONLY be loaded in tension (no bending forces), then the two-piecepart will be able to carry basically the same load as the solid piece.The piece that you are referring to (see attached images) will be primarily loadedin tension, so you might be all right with two thinner pieces edge-weldedtogether. But a better solution would be to use a solid piece. The title blockof Drawing No. 3 calls for 1020 steel, not 4130. So, if you can't find a pieceof 5/16" steel locally, I'm sure you could find a piece of 3/8" thick steel.That would provide 20% more strength, and only add one ounce to the total weightof your plane. Alternately, if you can get your hands on a bit of 1/4" thick4130, that would also work, since that would be stronger than 5/16" thick 1020steel.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/lg_1 ... ___Subject: Pietenpol-List: Re: Avionics package
Re: Pietenpol-List: Re: Avionics package
Your welcome Mr Jim.Clif>> Wow, those pictures are inspiring! And now I know how to do my fuel > shutoff!!!>> Thanks Clif.________________________________________________________________________________
