Pietenpol-List: Ford Engine Modifications
Original Posted By: "PShipman"
My economy jig.dave--------Covering PietRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/piet ... ___Subject: Pietenpol-List: Ford Engine Modifications
Original Posted By:> perrytshipman(at)gmail.com
Talk to Pieti Lowell. I think his puts out aroung 90hp.Doug DeverIn beautiful Stow Ohio> Subject: Pietenpol-List: Ford Engine Modifications
In talking with the Model A hot rodders the biggest problem with it is it deosn't breath well. Bigger intake valves do more to increase hp than anything. You could probably go to 5.9:1 without any problems if you call that high compression. Lowell?Doug DeverIn beautiful Stow Ohio> Subject: Pietenpol-List: Ford Engine Modifications
Original Posted By: "Amsafetyc(at)gmail.com"
An A or B can have inserts and a 6.5 compression ratio, I installed fuel injectionon my A in 1992, ran it 2 years , and completely dissembled it to check it'sBabbitt, There was no problems, When using a 76 X 42 Prop the RPM increasedto 2500 at full throttle , Even at that speed there was no damage to the engine,The B I now run is highly modified with close to 80 HP, swinging a 76 X 47prop. With many mods it was worked on in 1988, torn down for inspection twice. reassembled and is still working well.Carburetor in important, The best HP that I found , was a progressive two barrel.Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: Ford Engine Modifications
What about a length of piano wire pushed through between the two pieces of metalthen wrap each end around a short piece of broom stick and cut the glue that'show I have seen windscreens that are glued in cars removedCarsonRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Ford Engine Modifications
Re: Pietenpol-List: Ford Engine Modifications
http://www.amuffler.com/dyno/dyno1.htmh ... e.com/Clif In talking with the Model A hot rodders the biggest problem with it is it deosn't breath well. Bigger intake valves do more to increase hp than anything. You could probably go to 5.9:1 without any problems if you call that high compression. Lowell? Doug Dever________________________________________________________________________________
=0A=0A =0A=0APieters,=0A-=0AFor what it might be worth.=0A-=0AOne night a long time ago I was having a difficult time falling asleep. I =0Agot up and started downstairs when the wife asked where and why. I replied that =0AI intended to run a tape on all Piet invoices. In her sweet way she softly said =0Awhy not let them alone in the drawer and enjoy building. I did as she suggested =0Aand actually finished and flew my Piet and never worried about cost.=0A-=0ACorky and Isabelle=0A________________________________________________________________________________Subject: Pietenpol-List: Re: Ford Engine Modifications
Original Posted By: "Dick N"
Ron Kelly's tests got me trying his stuff and it worked for me, also the rod tricks,camhead all ad to big dependable HP. Douwe, tried some of his ideas also.The ultimate would be the the " Donivan " D , Looks like a Ford but don't kid yourself,who wants to fly with a look a like that will scare you . Plus it willrun in excess of $25, 000,00. Al cast block for racing 500 plus at 8,000, detunedwill still run 150 at aircraft RPMs.Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Ernest Kestler paint job??
I just received a flyer from Wag aero. On page 21 there are turnbuckle barrels listed at $2.00 each. That is a great price for anybone who is at that stage of construction. For the other parts of the turnbuckle assy I have seen them at Sun n Fun at B& B and other parts places cheaper.Grab while they are there.Dick N.________________________________________________________________________________Date: Mon, 31 Jan 2011 18:21:50 -0700Subject: Re: Pietenpol-List: Ernest Kestler paint job??
> ** Pietenpol-List: Ernest Kestler paint job??
RE: Pietenpol-List: Ernest Kestler paint job??
> To: pietenpol-list(at)matronics.com> >> > Has anyone built a Piet with a modified Model A Ford engine (i.e. high compression head=2C high torque cam=2C etc.)?> > If so=2C what have been the results?> > If not=2C what have been the concerns that have kept folks from doing that?> > --------> Perry Shipman> Lakeside=2C CA> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 903#328903> > > > > > > ============================================> > > ________________________________________________________________________________
> To: pietenpol-list(at)matronics.com> >> > Has anyone built a Piet with a modified Model A Ford engine (i.e. high compression head=2C high torque cam=2C etc.)?> > If so=2C what have been the results?> > If not=2C what have been the concerns that have kept folks from doing that?> > --------> Perry Shipman> Lakeside=2C CA> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 903#328903> > > > > > > ============================================> > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Ford Engine Modifications
Original Posted By:> ** owner-pietenpol-list-server(at)matronics.com [mailto:
>>> Cool, Shad! I had no idea you were restoring a Jungmeister. Where did> you get it?>>> I spent some time in the early =9180=92s helping restore a B=FCcker Jungmann.> Strange ribstitching those Germans did=85>>> Jack Phillips>> NX899JP =93Icarus Plummet=94>> Raleigh, NC>>> ------------------------------>
