Pietenpol-List: down to the fuselage
Why aren't we out there measuring real life airplanes?I'm presently renting an early Citabria. It is aerobaticcertified. Although it does have a longer,wider wing,it is about the same length as a Piet. I haven't measuredthe tail surfaces but the elevators appear to have a littleless area than my Piet and they appear to have about20 or so in deflection. The wheels are a little aheadof the wing LE in level stance. The engine is a 100hpO-235. ( I said it was early. :-) )Take-off is advance throttle and stick together. the tailcomes right up immediately. Landing the thing doesn'ttake full rear stick until it quits flying either.Clif> They recommend 20 degrees up and 20 degrees down for the elevators.> Mathematically, that works out to just over 6" up and 6" down.>> Bill C.________________________________________________________________________________Subject: Pietenpol-List: down to the fuselage
Pietenpol-List: Re: down to the fuselage
I have a Luscombe 8 manual and it has the elevator set at 29 degrees up and down.I set my Piet at 30 degrees each way.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: down to the fuselage
Looks like the differential in the background is a bit heavy duty for your Pietenpol[Wink] The cover job is looking good.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: down to the fuselage
figured I use the rear end on the Travel Air 4000 for rough landings and the fireextinguisher to put out the brake fire if I have one.And thats not only aneyewash station its my shower,kinda crude up here at 9000'.B'day is the 26th-thanksJack dave--------Covering PietRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 07 Feb 2011 08:33:32 -0600
Re: Pietenpol-List: Re: down to the fuselage
All great people were born in February. Mine is the 18th. Chuck (Do not archive)----- Original Message -----
Pietenpol-List: Re: Shad's Piet...
Original Posted By: "K5YAC"
Never mind that Jesus guy, right? Chuck Campbell wrote:> All great people were born in February. Mine is the 18th. Chuck (Do not > archive)> > --- [Laughing]--------Mark ChouinardWings, Center Section and Empannage framed up - Working on FuselageRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Shad's Piet...
Well! Nice to see us Februaries are recognized so grandly.Feb 25 for me.>> All great people were born in February. Mine is the 18th. Chuck (Do not > archive).B'day is the 26th-thanks Jack dave>>>> -------->> Covering Piet________________________________________________________________________________Date: Tue, 8 Feb 2011 06:56:11 -0800 (PST)
Re: Pietenpol-List: Room For Bungee Cord
Re: Pietenpol-List: need help with wiring
Feb 13 for me!--------Gary WilsonGreenville Wisconsingtche98 (at) gmail ((dot)) comPlanning PhaseRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 8 Feb 2011 10:59:19 -0700Subject: Re: Pietenpol-List: need help with wiring
Original Posted By: "gtche98"
We need to have one big humongous party for all Februaryites. Do not archive----- Original Message -----
