Weighed my Scott tail wheel at 4.9 pounds. The Matco is 4.75 pounds pertheir site. Both 6" solid rubber. My leaf springs cam in at 2.5 pounds.JackDSM________________________________________________________________________________
Pietenpol-List: Tail Wheel Weight FYI
RE: Pietenpol-List: Tail Wheel Weight FYI
Try the AS&S Homebuilt Special tailwheel. I think it weighs around 3 lbs(4" diameter). And the Pietenpol A-Arm Coil Spring configuration is about apound or two lighter than a leaf spring. I cut 2 lbs off my tailwheelweight by using that design with the 4" tailwheel instead of a 6".Jack PhillipsNX899JP "Icarus Plummet"Raleigh, NC _____
Re: Pietenpol-List: Tail Wheel Weight FYI
Tail Wheel Weight FYI ----- Original Message -----
Tail Wheel Weight FYIRe: AS&S Homebuilt Special tailwheel. Jack, I am very interested in the tail wheel you mentioned. I can't find it in the AS&S listing for tailwheels. How do I find it? Chuck in Winston-Salem. ----- Original Message -----
http://www.aircraftspruce.com/catalog/l ... el.phpJack PhillipsNX899JP "Icarus Plummet"Raleigh, NC _____
Tail Wheel Weight FYIThanks, Jack, but for $130 I believe I can stand an extra 2 pounds back there. If I have to, I'll move the wing back a fraction. ----- Original Message -----
