Pietenpol-List: Tail Wheel Weight FYI
Weighed my Scott tail wheel at 4.9 pounds. The Matco is 4.75 pounds pertheir site. Both 6" solid rubber. My leaf springs cam in at 2.5 pounds.JackDSM________________________________________________________________________________
RE: Pietenpol-List: Tail Wheel Weight FYI
Try the AS&S Homebuilt Special tailwheel. I think it weighs around 3 lbs(4" diameter). And the Pietenpol A-Arm Coil Spring configuration is about apound or two lighter than a leaf spring. I cut 2 lbs off my tailwheelweight by using that design with the 4" tailwheel instead of a 6".Jack PhillipsNX899JP "Icarus Plummet"Raleigh, NC _____
Re: Pietenpol-List: Tail Wheel Weight FYI
Tail Wheel Weight FYI ----- Original Message -----
Tail Wheel Weight FYIRe: AS&S Homebuilt Special tailwheel. Jack, I am very interested in the tail wheel you mentioned. I can't find it in the AS&S listing for tailwheels. How do I find it? Chuck in Winston-Salem. ----- Original Message -----
http://www.aircraftspruce.com/catalog/l ... el.phpJack PhillipsNX899JP "Icarus Plummet"Raleigh, NC _____
Tail Wheel Weight FYIThanks, Jack, but for $130 I believe I can stand an extra 2 pounds back there. If I have to, I'll move the wing back a fraction. ----- Original Message -----
