Pietenpol-List: FW: [Flitzer-Builders] here you go Ivan
Original Posted By: Flitzer-Builders(at)yahoogroups.com
Hey guys! Look what I saw on the Flitzer List! Anyone recognize that guy in the upper left? Also, on the right is Patrick Hoyt, 601 builder, and, most notably, powered with a Corvair! I heard his EAA chapter was building a Piet.Gary Boothe
Pietenpol-List: Re: [Flitzer-Builders] here you go Ivan
Careful Jack - Less than 24 hours to go...Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: [Flitzer-Builders] here you go Ivan
Actually, since you're in Australia now Ken, the time is up for you, sincethis is already March 18 there. So if I send disparaging remarks aboutCorvairs to you, and copy the rest of the Pietenpol list, that should be ok,right?Jack PhillipsNX899JP "Icarus Plummet"Raleigh, NC-----Original Message-----
