Pietenpol-List: FW: Visit to John McPherson
Pietenpol-List: Re: Visit to John McPherson
I was looking at the reassembly portion of the carb overhaul manual, and it refers to shellacking. Doesanyone know of a modern alternative or if off the shelf shellac from Lowes will work?Dave, let me know when you hear from Mike if hewants the seat or not. He might be stuck in the hangarwithout a computer.Curt MerdanFlower Mound, TXfrom the Stromberg overhaul manual:REASSEMBLY: All headless screw plugsbelow the fuel level should be assembled withshellac, being careful not to get it on the end ofthe plug where it will come off and be carried bythe fuel into one of the metering orifices. Head-less screw plugs above the fuel level and all otherthreaded parts screwed into the bodies shouldhave a compound of graphite and castor oil puton the threads.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Visit to John McPherson
Those Eisemann mags are quite common among older planes. Parts are available.Have John call Jeff Scott in Los Alamos, NM at (505) 412-0910 and I'm sure hewill be glad to help with information on servicing them.--------Oscar ZunigaSan Antonio, TXAir Camper NX41CCRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Visit to John McPherson
Kelly,I look forward to seeing you at the gathering in June! Email me your addressoff list and I'll send you the flyer. And you're welcome to come see our project as is any other builder passing throughour part of the world. Mike GroahTulare CaliforniaSent from my iPhoneOn Mar 27, 2011, at 8:12 AM, "regchief" wrote:> > although I can't open the download, I don't have word on this laptop, frazierlake isn't that far from paso robles, so I will mark that date down on my calender.BTW, Mike, I finally got to see a piet in the flesh last week. I stopedby the Hiller aviation musuem, just south of San Fransisco, last week, and theyhave a model A powered one, but it is sitting way up high and could only viewfrom a short distance. I would still like to come up and see yours some day,particulary as your starting to cover.> > Kelly> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 169#335169> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Visit to John McPherson
RE: Pietenpol-List: Re: Visit to John McPherson
This may sound funny...but he (and we) could not find any evidence of aP-lead!!Gary -----Original Message-----
Ready to mount my control assembly. Considering the angle the aileroncables pass through the slot in the panel base up to the center sectionpulleys. I'm just guessing my wing will be 4 inches aft of perpendicular.(Is this average for a long fuselage, C-85, split gear, heavier than averagetail) Can someone help with the calculation of how far the aileron controlhorn needs to be forward of the slot in the panel base? Assuming a rise ofapproximately 46" (horn to slot 22" and slot to c-section 24") and wing aft4" equals having the horn 4" forward the slot?? Not sure I have that muchroom.Thanks!!JackDSM________________________________________________________________________________Subject: Pietenpol-List: Re: Visit to John McPherson
