Original Posted By: "flash308"
All,The plans call for an AN5 for the top rudder bar/post connection. Is an AN4ok for the bottom bolts for the post and brace?Thanks,JackDSM________________________________________________________________________________Subject: Pietenpol-List: Seat frame heights for long fuselage Piet
Original Posted By: "Chris"
What is the front and rear seat frame heights for long fuselage Pietenpol ?The plans do not show the measurements.[/list]Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Seat frame heights for long fuselage Piet
Same height as the short fuselage.ChrisSacramento, CaWestcoastpiet.com-----Original Message-----
Pietenpol-List: Re: Seat frame heights for long fuselage Piet
Tom,It is my understanding that all of the wood gets shipped from Aircraft Spruce West,not East (GA). But having said that, I will check for sure. If you have contactinfo for those guys you mentioned, that would be much appreciated. I don't mind ripping, planing, and cutting my own wood. I am sort of in the endurancerun mode, not the sprint. I want to take it slow, easy, and enjoy the process.I will finish the airplane when I finish it, and not a day sooner. I amalso in the "I found a good deal by searching and scrounging" mode as well.Thanks for the advice.--------Semper Fi,TerryRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Seat frame heights for long fuselage Piet
Pietenpol-List: Re: Looking for a wood supplier in Minneapolis
Catdesigns wrote:> Same height as the short fuselage.> > Chris> Sacramento, Ca> Westcoastpiet.com> > > --May I ask what the measurements are. I am looking for distance from floor frontand back of seat. It also appears that they are different front and rear seatsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Looking for a wood supplier in Minneapolis
I don't care what they were powered with its a shame three nice Pietenpols weredamaged this way. I feel sorry for the guys that put all that time and work intothem and now see them all piled in a ball. I hope they all are rebuilt andreturn to the air. LarryRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Seat frame heights for long fuselage Piet
I think the plans show the front seat is 7 5/8" highand the rear is 6" at the front end--------Earl BrownI may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Referencing the sheet that says Drawing No. 1 on the top right hand corner. Front seat is 7-5/8 inches high above the floor and appears to be level front toback.Rear seat is 6 inches in the front and even with the top of the extra long gussetin the back, which would be 2-1/4 inch high from the bottom of the longeron.Chris--------ChrisSacramento, CAWestCoastPiet.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 4 Apr 2011 09:02:05 -0700 (PDT)
