Pietenpol-List: aileron deflection
Original Posted By: "Bob edson"
I have finally gotten back at working on the Piet and have an aileron question. How far down should the aileron move in full deflection. While sanding and rounding off corners today I noticed that the ailerons don=99t seem to move down very far. The bolt heads on the hinges stop the movement. I could recess the bolt heads and gain some but perhaps I did not angle the front spar of the aileron enough. Would someone measure the inches or angle that the aileron deflects downward on a flying Piet and help me out please? I know the ailerons on my Chief deflect more but I never use full deflection when flying so it is hard to compare.Thank a lot.Ralph in SD________________________________________________________________________________
Pietenpol-List: Re: aileron deflection
Jack, We live in Branson Mo and the plane will be based at the Taney County Airport . The motor is an 0-200 with one hour run time on it. Hope to see Brodhead this summer. Bob ________________________________________________________________________________Subject: Pietenpol-List: Re: aileron deflection
Using .040" thick piano hinges for my ailerons and dimpling for 10-32 flatheads(toset flush), I get 20.6 degrees of down travel before the hinge plates closetight on each other.--------PAPA MIKERead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 16 Apr 2012 06:10:45 -0700 (PDT)
Original Posted By: "899PM"
> Subject: RE: Pietenpol-List: Re: Wing Tip Bows>>> Additional thought, John...I think it was Skip Gadd who talked about> trammeling at least 3 times, during each phase of the construct. Seemslike> it would be a mistake to trammel the first time after the leading and> trailing edges are on.>> Gary from Cool> NX308MB________________________________________________________________________________Subject: Pietenpol-List: Re: aileron deflection
