Pietenpol-List: Wing Tip Transition
I would like to see pictures of how some of you transitioned the wing tip to theleading and trailing edge.ThanksJohn--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Wing Tip Transition
You can see the corner of the wingtip in the foregroud of this picture(ignore me sitting in my fuselage making airplane noises). I mixedmicroballoons with epoxy to make a thick slurry and globbed it in place,then sanded it smooth.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Pietenpol-List: Re: Wing Tip Transition
May be this help?..--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/dsc0 ... __________
Re: Pietenpol-List: Wing Tip Transition
Original Posted By: "Kringle"
#2. John, as you will notice in some of my pictures, I didn't take the aileron all the way to the tip. I used what some call an "encapsulated" aileron. C----- Original Message -----
Pietenpol-List: Re: Corvair CHT
Original Posted By: "Chris"
do you have the bottom air baffles under the cylinders? also I made some closefitting plates to fit against the rear of the heads to prevent air escaping atthe back and force it all down through the cylinder/ head fins with the exceptionof the oil cooler and tried to close any areas around the outside of thatalso.my single temp pickup is under one head bolt nut- when checked on the groundruns with a good quality heat gun the readings were within 15 to 20 degreesof the surrounding head surfaces. and mine never climbed over 290 in earlytesting.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
JohnI made the top of the wing tip bow to be flush with the top of the leadingedge. The bottom of the leading edge was tapered from the last wing rib upto the bottom of wing tip bow. I also added a filler block behind the jointso I could radius the corner.http://westcoastpiet.com/images/Chris%2 ... 559.JPGYou didn't ask but you will also need to taper the wing tip bow to thethickness of the aileron trailing edge. My taper starts just past the rearspar. I made the top of the bow equal to the top of the trailing edge soall I had to do was make one cut off the bottom of the bow.http://westcoastpiet.com/images/Chris%2 ... Sacramento, CaWestcoastpiet.com-----Original Message-----
Original Posted By: Hans van der Voort
RE: Pietenpol-List: Engine "Screw, Dowel"
Original Posted By: Virginia =0A=0A =C2- =0A=0A=0A=0A=0A=0A=0A=0A=0A=0A owner-pietenpol
=0A=0A=0A =0A =0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0AI assume you are talking about a=0AContinental A65?=C2- Try Fresno Airparts (559) 237-4863=C2- email fresnoairparts(at)att.net .=C2- They=0Ahave an ad on the first page of every Trade-a-Plane and carry every part for=0Athe small Continentals.=C2- They list =9CCrankcase clamping dowel bolt,=0Anut set for $47.50. =0A=0A =C2- =0A=0AJack Phillips =0A=0ANX899JP =0A=0ASmith Mountain Lake,
Some more pics John http://textors.com/8-31-08_012.jpg Jack TextorDSMNX1929T-----Original Message-----
Thanks all for pictures. Ive saved them to my iPad for future reference. John--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wing Tip Transition
Michael,Perhaps the photo you attached is an older photo, and this has already been addressed,but it looks like you would need some additional bracing at your wingtip. There was a recent discussion here on the List that brought up the pointthat the wing tip bow actually acts as a compression strut. Your photo appearsto show a wing tip bow that is even slimmer than the "plans" version. The structureshown in your photo likely will not be stout enough. It would be prudentto introduce a compression strut similar to those at the wing root and mid-wing.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 25 Apr 2012 06:10:21 -0700 (PDT)
Re: Pietenpol-List: Re: Wing Tip Transition
I assume you are talking about a Continental A65? Try Fresno Airparts (559)237-4863 email fresnoairparts(at)att.net . They have an ad on the first pageof every Trade-a-Plane and carry every part for the small Continentals.They list "Crankcase clamping dowel bolt, nut set for $47.50.Jack PhillipsNX899JPSmith Mountain Lake, Virginia _____
John, the first time I sent some pictures it was rejected by the list for being too large. Maybe this one will go through. The wing is upside down in both pictures. I didn't run my aileron all the way to the tip. C----- Original Message -----
I doubt that I will have the 40 hours flown off for Brodhead this year Jack buthopefully 2013.Rick--------Rick HollandRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wing Tip Transition
I am learning english with you ;o)--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wing Tip Transition
Original Posted By: Bill Princell
Mario,Your English is much better than my Spanish!Do no archive--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: put your cards on the table Gents and Ladies!
Original Posted By: airlion
Subject: Pietenpol-List: Re: put your cards on the table Gents and Ladies!Bill Princell - Noblesville, INStarted a complete rebuild and design upgrade of N10837 on 6-05 which hadbeen severally damaged in a central Texas landing accident.My project is a Piet/Grega hybrid with an oversize fuselage (plus 2" wideand 3" deep) and a 44" wide wing center section.Removed and sold original Subaru EA81 engine - Rebuilt a 1965 CorvairEngine w/William Wynne conversion parts and a Dan's 5th Bearing. Engine ranat CC#20 held in Michigan on weekend of June 3, 2011.New wings and center section build and completed using Riblett 612 airfoilwith continuous aileron hinges. Made 4 new Cabane struts w/support cables.New fin/rudder and elevator/stabilizer w/push/pull rod control system and acontinuous (no gap) hinge system. Made 8 new support cables w/turnbuckles.Cockpit interiors completed. New aluminum instrument panel completed w/newsteam gauges installed. All new electrical system and wiring installed.New Cub type gear w/6:00x6 wheels and tires and disc type brakes.New engine mount for Corvair engine built and installed.All metal surfaces have been powder coated.Will start fabric covering this fall using Stewart Systems process w/Latexpaint. Using light weight fabric and w/medium weight fabric on uppersurface of wings.Hope to complete and first flight in 2014.________________________________________________________________________________Date: Wed, 25 Apr 2012 11:00:38 -0700 (PDT)
Re: Pietenpol-List: Engine "Screw, Dowel"
Subject: Re: Pietenpol-List: Engine "Screw, Dowel"
Good planSent from my iPhoneOn Apr 25, 2012, at 7:19 PM, Michael Perez wrote:> Thanks Ben, I have all the old bolts, some are not worth keeping. I figure going through the engine like I am, I should buy new bolts.> > Michael Perez> Pietenpol HINT Videos> Karetaker Aero> www.karetakeraero.com> > > ============================================================================================================================================> ________________________________________________________________________________
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________________________________________________________________________________Subject: Pietenpol-List: Re: Wing Tip Transition
Chuck and Michael,Just out of curiosity... why did you decide not to run the ailerons all the wayto the tip? Just curious, that's all...Don EmchNX899DERead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wing Tip Transition
John,Absolutely! When I get home later I will send some to you. I have others too.From different angles. It was during the Brodhead Piet Fly-in in '07. Thephotographer, if I remember correctly worked for USA Today and flew with AndrewKing in his T-craft. I think he was on his way to Oshkosh and asked if he couldget some aerial shots.Don EmchNX899DERead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Don, I think it was more for asthetics than anything else. I just have never flown an airplane (and I have flown a bunch of them) where the aileron went all the way to the wing tip. If I lose any aileron effectiveness by losing that 5-inches of aileron, then I'll just have to be careful. Do what you think best. Chuck----- Original Message -----
Rick - I went to whatever Polyfiber said to go to. 350? I had one problem withthe fabric on the top of the wing deforming the structure around the fuel tankhole. Hurt my feelings a little bit but I reinforced the woodwork and droveon. Jack's right: if the structure is sound you won't have a problem. I thoughtthe structure around the wing tank was sufficient but it obviously wasn't.The rest of the shrinking process was trouble-free, and was actually my absolutefavorite part of the build. The piet's really stout and there should be no problem with tearing up a plans-builtairplane when shrinking the fabric to the manufacturer's standard.--------Kevin "Axel" PurteeNX899KPAustin/San Marcos, TXRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wing Tip Transition
Michael and Chuck,Personal preference is as good a reason as any I guess. I think the ailerons extendingall the way to the end was more popular in the 20's and early 30's. Lateron as they developed more effective ailerons I think they started to endthem before the end of the wing. Some of the early Travel Airs, Wacos, etc. had"elephant ears" or ailerons that actually extended past the wingtip. So Iguess it was the thing to do back then. Don EmchNX899DERead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 29 Apr 2012 16:29:43 -0700 (PDT)
Re: Pietenpol-List: fabric shrink temperature
Original Posted By: Rick Schreiber
Rick,I went with 350, BUT make sure you reinforce the end ribs. In my case (one-piece wing) the rib adjacent to the tank (center) was pulled out of position a little. Not good.Dan HelsperPuryear, TN-----Original Message-----
Bellanca tips. :-)Long and distinquished history.ClifTo most people the sky is the limit.To a pilot, the sky is home. Don, I had the wing tip shape in mind soon after I started building the wings. Michael Perez ________________________________________________________________________________Date: Mon, 30 Apr 2012 04:32:44 -0500Subject: Re: Pietenpol-List: Re: Wing Tip Transition
Subject: Corvair CHTPietenpol-List Digest List I have a CHT gauge on my Pietenpol with sensors under the rear spark plugsof each cylinder head.Can anyone tell me the maximum temperature that the Corvair heads should berun at ?Thanks,Rod WoollerZK-PAC________________________________________________________________________________Subject: Pietenpol-List: Wing Tip Transition
Sat, Apr 21, 2012 at 9:29 PM=0A Corvair CHT=0ATo: Pietenpol-List D
Original Posted By: "Jack"
Sat, Apr 21, 2012 at 9:29 PM=0ASubject: Corvair CHT=0ATo: Pietenpol-List Digest Server , Pietenpol-List Digest List =0A=0A=0AI have a CHT gauge on my Pietenpol with sensors under the rear spark plugs of each cylinder head.=0ACan anyone tell me the maximum temperature that the Corvair heads should be run at======== ________________________________________________________________________________
