Pietenpol-List: lowell
Pietenpol-List: Re: Don Harpers Pietenpol
Attached picture of of Don Harpers Piet making it's first engine run after filling fuel tank with gas. Taxi testing will start shortly. -After the first flight, more info will be posted.________________________________________________________________________________Subject: Pietenpol-List: Re: Don Harpers Pietenpol
Original Posted By: "Barnwell Regional Airport"
Hey Lowell (pieti)We'll miss your plane at Brodhead as she's been quite the institution for somany years. I hope you can get the "green light" from the docs to go flyingagain, but until then, keep coming yourself. It'll keep you young!Douwe________________________________________________________________________________
Attached picture of of Don Harpers Piet making it's first engine run after filling fuel tank with gas. Taxi testing will start shortly. After the first flight, more info will be posted.________________________________________________________________________________Subject: Pietenpol-List: Re: Don Harpers Pietenpol
Re: Pietenpol-List: Re: Don Harpers Pietenpol
Looks like a mighty fine aircraft Don! Can't wait to hear the flying numbers.I took a nap while the picture was downloading on my computer! Just kidding, buthere is a smaller version of the same for those with slow connections.--------John FrancisRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/img_ ... ___Subject: Re: Pietenpol-List: Re: Don Harpers Pietenpol
Original Posted By: airlion
Don:She is gorgeous, I have two questions,1.Don, is the leading wing edge with more radii ?2. Is the damaged pointing finger, aircraft related ?Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Don Harpers Pietenpol
Jealousy doesn't look good on me...Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Don Harpers new Pietenpol
Congratulations to Lowel for noting that the leading edge on Don's new Pietenpol is a little different . It is actualy a Riblet 612 airfoil.How does it fly? At this point, I've only done some high speed taxing. Several minor things were noted and are being corrected Don is working on getting paperwork together for inspected, scheduling a DAR, etc.More about flight information later.________________________________________________________________________________Subject: Re: Pietenpol-List: Don Harpers new Pietenpol
Original Posted By: Barnwell Regional Airport
Hi P.F.,Beautiful airplane indeed. The flight testing of Don's airplane will be the "final word" on the "airfoil wars", right? You and Don were telling me at Brodhead that his airplane is pretty much identical to yours with the exception of the Riblet airfoil, correct?Dan HelsperPuryear, TN-----Original Message-----
