Subject: Pietenpol-List: filling up the spar web sections---with 1/4" thick mahoganyor birch plyTools, I built up the areas where I had to attach wing fittings with 1/4" mahogany plywood on each side ofthe web area. I chamfered the ends of those filler plates on the advice of an aeronautical engineer. I attached an example in the form of a sketch which should help to illustrate how I did this. Mike C.________________________________________________________________________________Date: Wed, 5 Sep 2012 11:34:40 -0500 (GMT-05:00)
