Pietenpol-List: wing hoist
Original Posted By: "Scott Knowlton "
Hello all,I need to hoist a set of (covered) Piet wings into the rafters of my hangarfor some mid term storage. Any advice on how/how not to do this so that Ican get them up and down without damage?Thx!JMG________________________________________________________________________________
Original Posted By: Mario Giacummo
Subject: Pietenpol-List: wing hoistHello all, I need to hoist a set of (covered) Piet wings into the rafters of my hangar forsome mid term storage. Any advice on how/how not to do this so that I can getthem up and down without damage? Thx! ________________________________________________________________________________
Re: Pietenpol-List: wing hoist
Subject: Re: Pietenpol-List: wing hoistIf you have sufficient space above might I suggest you build a rolling wing stand(EAA has plans as does Tony B). Put two large bolted eyelits on the top ofthe stand either side and hoist the entire works with the wings on up into therafters. Worked great for a set of wings for me and I am able to break downthe wing stand. It has been loaned out to other builders on occasion. Less thana hundred bucks of wood and hardware to build. Scott Knowlton -----Original Message-----
Original Posted By:> John Greenlee
Subject: Re: Pietenpol-List: wing hoisthttp://members.eaa.org/home/homebuilders/building/workshop/4How%20to%20Make%20a%20Wing%20Stand.htmlMario Giacummo. -..- .. ... - .. .-. / . ... / ..- -. / .... . -.-. .... --- --..-- /...- .. ...- .. .-. / . ... / ..- -. / .- .-. - .2012/9/12 Scott Knowlton > flyingscott_k(at)hotmail.com>>> If you have sufficient space above might I suggest you build a rolling> wing stand (EAA has plans as does Tony B). Put two large bolted eyelits on> the top of the stand either side and hoist the entire works with the wings> on up into the rafters. Worked great for a set of wings for me and I am> able to break down the wing stand. It has been loaned out to other> builders on occasion. Less than a hundred bucks of wood and hardware to> build.>> Scott Knowlton>> -----Original Message-----
Subject: Pietenpol-List: wing hoistJohn,Attach about 100 Mylar Happy Birthday balloons to your wings after you wrap them in bubble pack and float themto the rafters. They'll come down gently as the helium leaks out of the balloons!Seriously, I would simply use the wing root fittings and the lift strut fittings with the wings upside down and use a systemlike this that is used for storing bicycles at the ceiling in garages.http://compare.ebay.com/like/1707821703 ... r=sbarMike C.[cid:image001.jpg(at)01CD90E3.565F3B30]________________________________________________________________________________
> To: > Subject: Pietenpol-List: wing hoist>>> Hello all,>> I need to hoist a set of (covered) Piet wings into the rafters of my> hangar for some mid term storage. Any advice on how/how not to do this so> that I can get them up and down without damage?>> Thx!>>________________________________________________________________________________
