Hello; as always asking something.Is there any problem in use ball bearings than bronze in the wheels hubs?, andwhat kind of ball bearing I have to use if I decide to use them?Thank you in advance. Best regards.--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Ball or bronze bearings in wheels?
RE: Pietenpol-List: Ball or bronze bearings in wheels?
Hi Mario,I don't know about ball bearings for an axle application. I'm not sure howwell they would react to side loading. Most people use bronze bushings. Iused tapered roller bearings on mine and they have worked well. You can buythem from McMaster-Carrr:http://www.mcmaster.com/#standard-ball- ... gs/=jn8lp0 Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Pietenpol-List: Re: Ball or bronze bearings in wheels?
Dan,Yes, that is the prop brother Tim carved out of mahogany planks while in college.I am ever amazed and humbled by his craftsmanship. Hard to think we are ofthe same genes. One thing of note for those with sharp eyeballs. Even though this is a GN-1, Ihave changed the strut and wing attach to be Pietenpol so I can translate thewing for CG purposes. I also made the CS 6" wider after visiting with Skip Gaddand his project. I need a wider flop in order to help get my fat a$$ in andout.--------David GallagherZodiac 601 XL-B: flying, 220+ hours nowNext project under construction: Finish my father's AircamperRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Ball or bronze bearings in wheels?
Original Posted By: Jim Boyer
Thank you Jack, most than enough.regards--------Mario Giacummohttp://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 9 Oct 2012 14:11:03 +0000 (UTC)
