artners, LLC]" Hmmmm....I never did install an ELT.---My inspector never said anything about it and I never spentthe money on it.---$588 for an ELT from Aircraft Spruce?---Wow am I out of touch.- href="http://www.matronics.com/Navigator?Pietenpol-List"; target=_blank href="http://forums.matronics.com/"; target=_blank>http://forums.matronbsp; - - - ---- List Contribution Web Site -" target="_blank">http://www.matronics.com/Navigator?Piet ... ___Subject: Pietenpol-List: Re: ELT?
Pietenpol-List: ELT? Now PLB Options
D. (GRC-RXD0)[Vantage Partners, LLC]" Hmmmm....I never did install an ELT. My inspector never said anything about it and I never spent the money on it. $588 for an ELT from Aircraft Spruce? Wow am I out of touch. href="http://www.matronics.com/Navigator?Pietenpol-List"; target=_blank href="http://forums.matronics.com/"; target=_blank>http://forums.matronbsp; - List Contribution Web Site - " target="_blank">http://www.matronics.com/Navigator?Piet ... ntribution" rel=nofollow target=_blank>http://www.matronics.com/Navigator?Piet ... cs.comllow target=_blank>http://www.matronics.com/contribution__ ... __________
Subject: Pietenpol-List: Re: ELT?> > Hey Dan > The 121.5 is legal...I got lucky and found one of those ebc 102 elt's..reallysmall and light> > jeff> Louisville ky> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 106#386106> > > > > > > > > > ________________________________________________________________________________
Re: Pietenpol-List: ELT?
Hi Dan,I don't believe the 406 is required yet. I just had to replace the one in my Cub and was still able to get the old one from ACS for about $160. Like Mikee, I don't have on in 503R either.-john-John HofmannVice-President, Information TechnologyThe Rees Group, Inc.2424 American LaneMadison, WI 53704Phone: 608.443.2468 ext 150Fax: 608.443.2474Email:-jhofmann(at)reesgroupinc.comOn Oct 27, 2012, at 7:05 AM, helspersew(at)aol.com wrote:Does this FAA reg actually say I have to put a 406MHZ ELT in my Piet at some point in the future? I was thinking I would just switch back and forth my existing $100 121.5 ELT that I have in the Aeronca.--Dan HelsperPuryear, TN------Original Message-----
Original Posted By: bender
Subject: Pietenpol-List: ELT? Now PLB Options I have a 4 year old "new" 121.5 ELT in my old bonanza. I just could not pop fora 406 at the time. 121.5 is no longer activly monitored and so is of less use.I would suggest getting one that uses common D Batteries, not special batteries.A little more up front cost that saves in the long run. My old ELT costup to $50 just for the special battery pack. My "new" one requires off the shelf"Coppertop" batteries, I buy new ones, pull the old ones for my flashlightsand keep moving. Easy and affordable.Based on disucssions with my fellow Vtail flyers I will buy a Personal LocatorBeacon (PLB). It sends your location to a sattelite every couple of minutes. I will probably get a SPOT based one. I may also look at other ones such as Spidertrack,inreach, or TracMe . They may require telling someone to check theiremail.Here is a description from wikipaedia.SPOTSPOT does not use the 406 MHz signal nor the system of satellites. Instead, itdepends on the GlobalStar satellite system. It has richer features (for instance,can send many non-emergency signals) but it does not work in as many placesas 406 MHz PLBs for instance under dense forest canopy or steep canyons.[34]When a user presses the "911" button on a SPOT device an emergency messagecontaining the unit's identification and GPS location is transmitted to the GEOSInternational Emergency Response Center who then notifies the appropriate emergencyagency for the region after first calling the user to ensure the transmissionis not accidental.[35][36]SPOT additionally has the ability to provide non-emergency web based tracking information.This allows family or friends at home to track the holder's progress.The tracking operates by sending a tracking signal to the GlobalStar networkevery 10 minutes. This feature can additionally be useful to provide locationof an individual even if the individual is unable to activate the emergency'911' button.[37]Typical costs are $169 plus a $99/year service fee for basic services or $150/yrfor basic services and tracking services, as compared to around $250 for a 406-MHzPLB with no service fee.Blue Skies,Steve D----- Original Message -----
Original Posted By:> shad bell
Hi Dan,I don't believe the 406 is required yet. I just had to replace the one in my Cub and was still able to get the old one from ACS for about $160. Like Mikee, I don't have on in 503R either.-john-John HofmannVice-President, Information TechnologyThe Rees Group, Inc.2424 American LaneMadison, WI 53704Phone: 608.443.2468 ext 150Fax: 608.443.2474Email: jhofmann(at)reesgroupinc.comOn Oct 27, 2012, at 7:05 AM, helspersew(at)aol.com wrote:> Does this FAA reg actually say I have to put a 406MHZ ELT in my Piet at some point in the future? I was thinking I would just switch back and forth my existing $100 121.5 ELT that I have in the Aeronca.> > > Dan Helsper> Puryear, TN> > -----Original Message-----
Pietenpol-List: Re: RE-PIET flying characteristics
The way I understand it, the basic 121.5 model is fine..The nice thing about the406 model, is you have the option of also wiring in your gps antenna....evenwith a small older handheld model like I have...so that it can pinpoint you whenyou crash...larryhttp://www.youtube.com/watch?v=ksmpLpkGsic&feature=plcpRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: RE-PIET flying characteristics
Douwe:If I were a betting man, I would bet that you're bringing Re-Piet down final atabout 63-65 MPH and that's why it's floating on down the runway. When you getyour GPS (or a REAL airspeed indicator), try flying final at 60, then at 57-58,then when you're comfortable with that, fly final at 54-55... but only ifit's not gusty. What a difference a few MPH makes-! At 55 MPH, Scout feels likeit's coming down on rails that are sloping at 45 degrees down to the threshold.If I'm high or fast on final, I can throw the airplane into a slip and get it downso fast that the ground almost swallows me up. I used to have to do thatto land it on the grass ahead of the paved runway at 8T8, because there was arow of trees on the final approach path and I would kick it into a hard slip overthe trees, kick it out down close to the grass, then roll out as pretty asyou please before getting to the paved threshold and let the grass do all thebraking. Great fun, and grass is so forgiving.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: Cuy, Michael D. (GRC-RXD0)[Vantage Partners,
Nope, as of Oct 4, 2012 anyway. It's still in thebureucracy wind.http://polarpilots.ca/index.php/whats-n ... 06-eltClif shad bell To: pietenpol-list(at)matronics.com Sent: Saturday, October 27, 2012 10:24 AM Subject: Re: Pietenpol-List: ELT? Canada require 406MHZ. Shad --- . -----Original Message----- Shad --- On Fri, 10/26/12, Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] wrote:
> (GRC-RXD0)[Vantage Partners, LLC]" > > Hmmmm....I never did install an ELT. My inspector never said anything about it and I never spent> the money on it. > > $588 for an ELT from Aircraft Spruce? Wow am I out of touch. href="http://www.matronics.com/Navigator?Pietenpol-List"; target=_blank href="http://forums.matronics.com/"; target=_blank>http://forums.matronbsp; - List Contribution Web Site -> > > > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List> tp://forums.matronics.com> _blank">http://www.matronics.com/contribution> > > > ________________________________________________________________________________Date: Sat, 27 Oct 2012 10:24:02 -0700 (PDT)
