Pietenpol-List: Obsolete Part?
All this my nose tank, a J3 tank. Any ideas what cap will fit?ThanksJackDQoNCg0KU2VudCBmcm9tIG15IGlQYWQNCkphY2sgVGV4dG9y________________________________________________________________________________Subject: Pietenpol-List: Obsolete Part?
Pietenpol-List: Re: ELT?
With today's modern fabric coverings with inspection plates and rings, is thispiece of plywood no longer needed? I looked at a few wings on WestCoast Piettoday and didn't see it.Thanks--------John FrancisRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/dsc0 ... ___Subject: Pietenpol-List: Re: ELT?
Pietenpol-List: Re: Obsolete Part?
I found this explanation from another site that explains it well:You can fly without an ELT if you have a single seat airplane or if you stay within50 miles of where the aircraft is based. You're legal if you install a 121.5ELT. The issue is that the satellites are not monitoring that freq, so your121.5 ELT doesn't have the utility it once did. You are then relying on otheraircraft to hear your ELT and/or the CAP cadets to find you.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Obsolete Part?
Pietenpol-List: Re: Tank cap
I would say that the plywood piece is totally obsolete, yes. Scout doesn't havethem.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Tank cap
Subject: Re: Pietenpol-List: corvair college #24 registrationHi P.F.I think I was probably one of the first to register. I plan to there withmy completed engine. I have repaired several small issues that surfacedwhen I ran it at Roy's last year. Just need to set the timing. Lookingforward to seeing you and some of the people I've met a previous colleges.Bill Princell -On Sun, Oct 28, 2012 at 9:18 AM, Barnwell Regional Airport wrote:> **> For those of you still undecided about coming to corvair college #24, time> is running out to register.>> I expect that Ken Pavlou will cut off registration no later than Tuesday> night. Click on> https://corvaircollege.wufoo.com/forms/ ... istration/> to register.>> For us Pietenpol fans, I expect at least 5 Pietenpols to show up as well> as a large number of KR-2's, Zenairs, Sonex and maybe some others. I realy> think that we will have the largest gathering of corvair powered planes> ever in one place.>> Look forward to seeing you here.>> P. F. Beck>>> *>> *>>________________________________________________________________________________Subject: Pietenpol-List: Re: Obsolete Part?
Pietenpol-List: Re: Article in Museum of Flight Newsletter...
I'm thinking the inspection rings put into the covering is the modern day equivalentto this part.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Article in Museum of Flight Newsletter...
Pietenpol-List: Re: RE-PIET flying characteristics
Way cool! Thanks for sharing.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: RE-PIET flying characteristics
Pietenpol-List: Re: servo trim system, and prop size
Thanks for the data! I LOVE these flight reports. Makes me wanna get mine done!MarkRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: servo trim system, and prop size
Re: Pietenpol-List: Re: Tank cap
Original Posted By: Jack
Douwe, I know you must have posted this recently, but what engine are you using?The 65 or a Corvair...?Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Tank cap
Original Posted By: "tools"
Oscar I think it's stock J3, came without cap. Threads are 2 21/64 and 2 23/64.The ID is 2 1/16. Would like to use screw type.Sent from my iPadJack TextorOn Oct 28, 2012, at 11:00 PM, "taildrags" wrote:> > Jack; are you going to use a threaded cap on it? If so, what size is the bung(threaded stub), inside and outside diameter and threads? There are a numberof caps that might fit. Is this a stock J-3 setup, with the float rod stickingup through the cap?> > --------> Oscar Zuniga> Medford, OR> Air Camper NX41CC "Scout"> A75 power> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 164#386164> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Tank cap
Jack,You're going to have better luck determining off site whether a cap will fit ifyou describe the threads in terms of threads per inch. Just put a ruler up toit and count them in an inch and specify the outside diameter.Can't remember if you count the first and last threads or not, so count the threadson a 1/4-20 bolt (or other known quantity) to get the procedure.Making one isn't really difficult should one not be available. Do you have a secondstub the same as that one? Using it as a gage while machining would ensurea good fit.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
