Pietenpol-List: Re: End of an Era
Subject: Pietenpol-List: Re: End of an Era> > Last flying example? Wow. I thought there were still lots of them around, butI guess I've got them mixed up with the Twin Beech.> > One of my "Round Sounds" audio CDs has a beautiful track on it that featuresan Electra from startup to leveling off in cruise, and when it > gets up to altitude and the engines and props are settled into a > nice synchronized hum it is one of the sweetest sounds you can > imagine.> --------> Oscar Zuniga> Medford, OR> Air Camper NX41CC "Scout"> A75 power> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 165#386165> > > > > > > > > > ________________________________________________________________________________
Jack; are you going to use a threaded cap on it? If so, what size is the bung(threaded stub), inside and outside diameter and threads? There are a numberof caps that might fit. Is this a stock J-3 setup, with the float rod stickingup through the cap?--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: End of an Era
Re: Pietenpol-List: Re: End of an Era
Original Posted By: taildrags
Subject: Re: Pietenpol-List: Re: End of an EraPerhaps they mean the last Electra 10-E. That was the model Earhart flew, only15 were made. There were about 130 or so of all models made. Also the Electra12 and 14 are pretty similar.I think there are several still flying. ----- Original Message -----
Re: Pietenpol-List: Tank cap
Jack, SOMEWHERE I have a copy of the GN-1 plans for a fibreglass copy of the J-3 tank and it shows a Piper part number for the cap with the fuel gauge float. As soon as I can find it I will send you a part number if it will do you any good. Chuck----- Original Message -----
