Pietenpol-List: Wing Spar help?
Thanks Scotty, Michael and Gary. I guess I wasn't worried about the toxicity with an open cockpit but since many didn't get back to me saying it was ok I plan to use aviation wire and connectors. I will save money using Chinese hardware. Kidding!Sent from my iPadJack TextorOn Nov 24, 2012, at 11:12 AM, Michael Perez wrote:> > The picture attached shows the wire I used. The foil is the shield and it is electrically connected to the bare wire. (ground) You only need to cut the conductors and ground to the length you need, add the end connectors and attach.> > Michael Perez> Pietenpol HINT Videos> Karetaker Aero> www.karetakeraero.com> > ________________________________________________________________________________Subject: Pietenpol-List: Wing Spar help?
Looking at the wing plans and getting ready to order wood for spars. Why couldn'ta guy just get alittle bigger piece and cut the top angle to fit the ribs soyou don't have to add the little angle filler pieces? Is there something I amover looking? Does no one do it because of the little more added weight of woodbetween the ribs? Or the cost of spruce for a bigger spar? Thanks for anyanswers.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Wing Spar help?
That is what Greg and I did on ours.Dale----- Original Message -----
Original Posted By:> ----- Original Message ----- "Pietflyer1977"
Cost of wood for taller spar. The wedges are a no brainier, extremely easy to do.Wayyyyy easier than Berlinger the top of spar. No good way to get glue underrib. Gene RamboOn Nov 24, 2012, at 7:16 PM, "Dale Johnson" wrote:> > That is what Greg and I did on ours.> > Dale
I am getting ready to order metal for the steel tail for my piet and I was wondering,has anyone compared the weight of a wood vs metal tail?--------Building steel fuselage aircamper.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Wing Spar help?
Original Posted By:>> ----- Original Message ----- "Pietflyer1977"
Beveling. Damned autospell!Gene RamboOn Nov 24, 2012, at 7:37 PM, Gene Rambo wrote:> > Cost of wood for taller spar. The wedges are a no brainier, extremely easy todo. Wayyyyy easier than Berlinger the top of spar. No good way to get glue underrib. > > Gene Rambo> > On Nov 24, 2012, at 7:16 PM, "Dale Johnson" wrote:> >> >> That is what Greg and I did on ours.>> >> Dale
Michael, they ARE needed if he doesn['t have the vertical members in the ribs to attach to the spar. You and I were smart by putting those vertical members in -- the older plans do not show the verticals. Oh! I forgot. I used the GN-1 rib plan for my ribs. That plan has the verticals at each spar location. Chuck ----- Original Message -----
