Spar thickness
Spar thickness
All, I know I will get a lot of varied responses on this one. I ordered some wood to build the wings and have been informed that the wood that has been found for the spars is just a shade(1/32-1/16th of an inch) under 1 inch thick. I am away from home for work but am pretty sure i remember the plans calling for 1 inch thick wood. That being said the question would be is wood that is a shade under 1 inch a problem. I know it will by necessity be less strong but can it really be that much less and is 1 inch really required for the weight and type of flying done in piets. Any thoughts?
Re: Spar thickness
Wannabe- there are Piets flying with 3/4" thick spars, although I don't recommend that without some knowledge of what you're doing and what type of wood it is. However, I would consider "a shade thinner" than 1" to be just fine. Just be sure to compensate for that if you decide to route out sections of the spar web, because it could get a little too thin if you don't. If you plan to use solid (non-routed) spars, you should be fine.
Re: Spar thickness
Taildrags, thanks for the reply, i don’t have a degree in aero so really cannot run any numbers to tell what the minimum thickness would need to be. That being said my “spidey sense” indicated that it should be fine but its always good to run ones ideas across someone else to make sure they are not too off the mark. Do you think there will be a problem fitting the ribs on the spar if they are built per the plans or is a little “slop” ok with the fit?
Re: Spar thickness
Wannabe- the ribs should slide onto the spars but they need to be a snug fit. The best way to do that is to cut off some short stub ends of your spar stock (assuming that you've got a little to spare... and the ends usually have a little checking or scuffing anyway)- and when you build your rib jig, cement those stubs in place on your jig and then build the ribs around the spar stubs. That way, the rib openings will be sized the same as your spars are, whatever thickness they end up being "just a shade thinner" than a full 1". You can cover the stubs with clear packing tape so the ribs and adhesive don't stick to them when you're gluing up the ribs.
Re: Spar thickness
Copy all, thanks. I am a hand tool wood worker so in my mind i was seeing myself doing lots of hand planing to get the ribs onto the spars.
Re: Spar thickness
I used 3/4 spruce for my spars, which I think is specified in the three piece wing plans (no routing needed). 160 hours and haven't fallen out of the sky yet.
Rick H
Rick H
Re: Spar thickness
Thanks Rick, I need some motivation to get back to the basement and do some more work on the plane and getting some hours on the airframe will do it.
Re: Spar thickness
A couple pictures of my 3/4" spars, notice that I epoxied 1/8" ply pieces to spar where the ribs attached so the ribs were built to plans with the 1" openings to slide on the front and rear spars.
RH
RH
Re: Spar thickness
Rick, unable to see pics, could be on my end though, the older i get the less i know(and wanna know) about electronics and computers, explains my choice in experimental aircraft.
Sean
Sean
Re: Spar thickness
Thanks for the pics Rick, it really helps me to see how others have solved things.
Re: Spar thickness
Further question re spar thickness -
I’m considering building 3/4” spars using laminations. Most likely method will be to make the spars thicker than 3/4” and then machine them down to the desired thickness. Theoretically, this is a stronger spar than a single piece spar of the same dimensions. 3 piece wing.
Anyway, to my question.
Why is there any need to glue 1/8” ply doublers onto the spar at the rib locations ?
Could I not just construct the ribs to fit a 3/4” spar snugly as alluded to in a post above.
Cheers.
Cheers.
Re: Spar thickness
Yes.
Re: Spar thickness
Hi folks.......... reactivating this discussion...... this is right where I am at....
1" vs 3/4" spars........ would love to hear your current thoughts. Here are some options as I see it. From my point.
a. 1 inch, non-routed
b. 1 inch, routed
c. 3/4 inch, non-router, with 1/8 strips glued to each side to make 1 inch at top and bottom.
d. 3/4 inch, non-router, build fittings to fit 3/4, change my rib jig to 3/4"
I think I am leaning toward (c) ............... Only cause I have my rib jig built, but have not built ribs yet. But it would not be hard to change it to 3/4"
Like so many things on this project, I have various reasons, for various decisions, to get various answers.
Also wondering your thoughts on availability of 1" vs 3/4".
thanks
Mark
b. 1 inch, routed
thanks
Mark
Re: Spar thickness
My thoughts are that I would stick with 1" thick spars. Stress-wise and for the same spar depth and wood species, a solid rectangular 1" thick spar can take 33% higher bending stress than a 3/4" spar so if you drop down from a solid 1" spar to a solid 3/4" spar, you've lost one-third of the spar's capacity in bending. If you then route out the web of a 3/4" thick spar, you reduce its strength even further. In order to calculate how much that further reduction might amount to, you would need to know how much you were going to route out.
As to the relative cost of 3/4" spar stock compared to 1" stock, it probably goes from 'wow' for 3/4" thick to 'holy smokes" for 1" these days. If you are handy with a table saw and epoxy, and can make some good scarf joints, and have plenty of clamps, you can avoid some of those costs by laminating your own spars. In that way, you don't have to search to find good, clear, straight, satisfactory, spar-length wood planks but can deal with shorter pieces that cost less, are easier to find, and easier to handle. In lieu of laminating your own spars and/or routing out the webs, you can also avoid the whole process of routing out the webs if you fabricate your own I-beam spars out of scarfed solid wood spar caps and then use plywood for the webs. This is what Mike Cuy and others did on their wings, with good success.
Re: Spar thickness
Hi Oscar........ thanks
good comments.
I traded emails with Andrew Pietenpole today and he said his grandfather did it both ways.
And the last one he did, he laminated a bunch of pieces together to make the spars.
I think at this point I have decided to stick with 1 inch, and just update the fittings and drawings on the center section to fit that size.
I too like the added strength of the 1 inch.
And with regards to weight, if I lost 20 lbs. myself, I would be healthier, and feel better etc....... and cover way more than the routing would.....
But would love to see all the comments and thoughts.
thanks
Mark
good comments.
thanks
Mark
Re: Spar thickness
On my Piet, I have 1" routed spars. I saved approximately 12 lbs with the routing. That might not sound like much. But my empty weight is just a tad past 700 lbs (I have a full electrical system including alternator, starter, com, transponder, and ADSB-out), which means that the routing equaled approximately 1.7% of the weight of my Piet. To me, that was worth a few extra days of work. Based on calculations that Oscar has provided, the routed 1" spars are still plenty beefy enough for weights and safety margins of a Piet with a max gross weight specified by Mr. Pietenpol.
Re: Spar thickness
I have routed 1 inch spars also. The routing didn't take long, and I got to buy a new tool.
Who doesn't like new tools? I have a couple of planes, now.. router bits.. a really nice chisel set from England..a tool to sharpen them, and have made several table saw tools.
And yes, the weight savings is worth it IMHO. I've always said that all other things being equal, the lighter airplane is the better airplane.
