Model A ignition harness
What is everyone using for an ignition harness with the model A? I have a slick 4201 mag mounted directly to end of the crank. The slick harness I have from a small continental comes up about 6" short. I am using standard REM 40E plugs.
Re: Model A ignition harness
We bought bulk Slick plug lead and made to fit.
Sounds good. Did you have to buy the $863 tool to swage the ends?
https://www.aircraftspruce.com/catalog/ ... ey=6621887
No. Already had a pin vise and bits to clean out the ends. Used a deep socket to set the ferrules.
Last edited by Richard Roller on Sun Dec 01, 2024 5:58 pm, edited 1 time in total.
Perfect. Thanks for the help. I will order a lead and change out the ones that are too short. I am sure I will have more questions.
It has been challenging getting the Ford engine and all of the engine systems mounted in the Corben. The underslung radiator and tight cowling have created the main headaches. I think it is getting close to run-able.
