Page 2 of 2
RE: Pietenpol-List: Engine Decals
Posted: Thu Jan 27, 2011 10:34 am
I made those and gave them to WW. I also made some for Aeromax and othersincluding the AirCamper logo. email me off-group and let me know what youneed.Barry Davis _____
Pietenpol-List: Re: antenna
Posted: Thu Jan 27, 2011 1:55 pm
Original Posted By: "Dick N"
I've received a couple of messages stating that my photo link didn't come throughproperly in the e-mail version. It's not a big deal... just a photo of a varietyof different BNC connectors. Here is the direct link for those that might be interested. --------Mark ChouinardWings, Center Section and Empannage framed up - Working on FuselageRead this topic online here:
Posted: Thu Jan 27, 2011 9:35 pm
Original Posted By: "MyrickPiet"
Definitely a lot of Mike Cuy in there! I also need to give credit to the personbehind the attached drawing. Who drew this? I must thank you!ChuckRead this topic online here:
http://forums.matronics.com//files/spar ... ___Subject: Pietenpol-List: Re: antenna
Posted: Sat Jan 29, 2011 5:48 pm
Original Posted By: "Ozarkflyer"
I got 'er done this morning. Propane torch did the trick. That is a nice pieceof metal and the price was O so right. It has flanges on each side 24 3/8" inside.All I will have to do is trim a little off the flanges and shape the bottomand top. I hope to finish welding the wing tank tomorrow. My son is comingover. His TIG welding is much better than mine.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: antenna
Posted: Sat Jan 29, 2011 6:15 pm
Original Posted By: Woodflier(at)aol.com
If you go to the RST engineering web site listed above, Weir has some informativehow-to articles that were published in Kitplanes.Read this topic online here:
> Re: antenna
Original Posted By: Jim Weir
> Subject: Re: antenna>> >This may not help once you have covered the tail, but for new builders it> >may be appropriate: BPAN #33 page 7 had an article by Maurice T. "Buz"> Baer> >about hiding a comm antenna in the vertical stabilizer. He used a 24"> >external braided shield over the RG58AU coax as a counterpoise> >(groundplane). He measured a 1:1 VSWR, showing a good impedance match at> >comm frequencies. No telephone number for him, but he was at Kansas> College> >of Technology, Salina KS 67401. His number may be in Reed's directory.> >> >Al Swanson> >swans071(at)gold.tc.umn.edu> >> >> >>Mike C wrote:> >>> >> >>> >>Mike - I'm running a non-shielded ignition system and was wondering> >>if you had shielded. I have a feeling I'd get lots of noise but still> hoping> >>for a possible solution.> >>> >>MIke C. >>>> >>> >>Yes, I have a shielded igntion. I have been running an 0-200 for the past> >10 years. Prior to that I had a Ford A and I can't remember if I had a> >handheld at that time.> >>> >>Why don't you try it with just the rubber ducky antenna?If it works,> >install the whip antenna.> >>> >>Mike B ( Piet N687MB )> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>Mike C wrote:> >>> >>Mike - I'm running a non-shielded> >ignition> >>system and was wonderingif you had shielded. I have a> feeling> >>I'd get lots of noise but still hopingfor a possible solution.> >MIke> >>C. > >>> >>Yes, I have a shielded> >>igntion. I have been running an 0-200 for the past 10 years. Prior to> >that> >>I had a Ford A and I can't remember if I had a handheld at that> >>time.> >>> >>Why don't you try it with just the rubber ducky antenna?If it works,> >>install the whip antenna.> >>> >>Mike B ( Piet N687MB )> >>> >>> >>> >>________________________________________________________________________________
> Re: antenna
> > As an old timer in ham radio, I can suggest that good antenna design canbe> had by contacting a ham radio group. They are accustomed to desiging this> sort of thing, esp. now days since it's one of the only components in a> radio station using modern equipment that can still be designed by the> operator.> > Kevin Southwick> N5KDP> down here in Houston> ________________________________________________________________________________
> To: pietenpol-list(at)matronics.com> t.net>> > Some things just seem like common sense. The Model-T didn't have seat belts but the steering had a habit of jack knifing easily. Probably would have been a lot more older Model-T drivers if seat belts were in fashion in those days.> > Jon> > --------> Jon Coxwell > GN-1 Builder> Recycle and preserve the planet> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 768#310768> > &g====================> _====> > > =0A=0A________________________________________________________________________________Subject: Pietenpol-List: Re: antenna
