Original Posted By: "Doug"
> Subject: Re: Pietenpol-List: Shoulder Harness> > > >> >Hi Doug> >> >Way back in the dark ages (aircamper days ) we didnt have to have> >shoulder harneses....all that came in about 95-95> >> >I was thinking of using a cable run from the tail, along the fuse,through> a> >pulley and across the center with another pulley or 2. then the samedown> >the other side. Attatch the 'y' harness to this cable.> >> >Nice thin about the setup is it cuts the load on each attatch point in1/2> >over a single point installation-easier on the airframe.> >> >I never got that far before the garage burned, so dont know whether ornot> >it would actually work.> >> >Mike> >-----Original Message-----> >From: Doug > >To: pietenpol-list(at)matronics.com > >Date: Tuesday, December 28, 1999 11:19 PM> >Subject: Pietenpol-List: Shoulder Harness> >> >> >>> >>To Dom,or other Canadian Piet drivers;> >> Did you install front cockpit shoulder harness,or just a lap belt?Ifyou> >>installed shoulder harness,where did you anchor them,can send me apicture> >>directly if one is available.> >> I suspect the US.regs might be different.> >> Thanks in advance.> >>Doug Hunt> >>C-GCGJ> >>> >>> >> >> > > > > ________________________________________________________________________________
Original Posted By: "kyle ray"
> > > Hi Doug,> I installed both. I attached it to the 1/8 " cross wires just behind the> passengers head.> Dom.> > > > > ________________________________________________________________________________
> > > Steve,> > I'll take a look if I have any pictures. I doubt that I have picturesfrom> inside the fuselage though. I could make you a drawing, scan it and sendit> to you if you like.> > Dom.> > > > > ________________________________________________________________________________
> Subject: Pietenpol-List: Shoulder Harness>>> I am considering putting shoulder harnesses in my Pietenpol. >> Does anyone have any ideas as to the best anchor point for the shoulderharness for the rear seat? Also what hardware have you found best to mountto the structure?>> Thanks, >> Joseph>>________________________________________________________________________________
Original Posted By: Ohbejoyful
> > Subject: Pietenpol-List: Shoulder Harness> >> >> > I am considering putting shoulder harnesses in my Pietenpol. > >> > Does anyone have any ideas as to the best anchor point for the shoulder> harness for the rear seat? Also what hardware have you found best to mount> to the structure?> >> > Thanks, > >> > Joseph> >> >> >> >> >> >> >> ________________________________________________________________________________Subject: Re: Pietenpol-List: Shoulder Harness
> RE: Pietenpol-List: Shoulder Harness
Original Posted By:>>> Ohbejoyful Subject: RE: Pietenpol-List: Shoulder Harness> To: pietenpol-list(at)matronics.com> > >> Joseph,>> Attached shows how I did my front and pilot pits. Keep in mind this >> Piethas not been off the ground. >> The 7/16 picture shows the 2nd or 3rd practice instrument board, I >> havesince moved the engine instruments to the right and the mag >> switch to the>> left, because when starting my Grega I am always standing at the >> prop or on>> the left side.>> Skip>> >> >>> [Original Message]
>>> Subject: Pietenpol-List: Shoulder Harness>>> >>> >>> I am considering putting shoulder harnesses in my Pietenpol. >>> >>> Does anyone have any ideas as to the best anchor point for the shoulder>> harness for the rear seat? Also what hardware have you found best to mount>> to the structure?>>> >>> Thanks, >>> >>> Joseph>>> >>> >>> >>> >>> >>> >>> >> > > > > ________________________________________________________________________________
Pietenpol-List: Re: Shoulder Harness
> Subject: Pietenpol-List: Shoulder Harness>>> I am considering putting shoulder harnesses in my Pietenpol. >> Does anyone have any ideas as to the best anchor point for the shoulderharness for the rear seat? Also what hardware have you found best to mountto the structure?>> Thanks, >> Joseph>>________________________________________________________________________________Subject: Pietenpol-List: Re: Shoulder Harness
