> > Pietenpol-List: Shoulder Harness
Original Posted By: "Doug"
> Subject: Re: Pietenpol-List: Shoulder Harness> > > >> >Hi Doug> >> >Way back in the dark ages (aircamper days ) we didnt have to have> >shoulder harneses....all that came in about 95-95> >> >I was thinking of using a cable run from the tail, along the fuse,through> a> >pulley and across the center with another pulley or 2. then the samedown> >the other side. Attatch the 'y' harness to this cable.> >> >Nice thin about the setup is it cuts the load on each attatch point in1/2> >over a single point installation-easier on the airframe.> >> >I never got that far before the garage burned, so dont know whether ornot> >it would actually work.> >> >Mike> >-----Original Message-----> >From: Doug > >To: pietenpol-list(at)matronics.com > >Date: Tuesday, December 28, 1999 11:19 PM> >Subject: Pietenpol-List: Shoulder Harness> >> >> >>> >>To Dom,or other Canadian Piet drivers;> >> Did you install front cockpit shoulder harness,or just a lap belt?Ifyou> >>installed shoulder harness,where did you anchor them,can send me apicture> >>directly if one is available.> >> I suspect the US.regs might be different.> >> Thanks in advance.> >>Doug Hunt> >>C-GCGJ> >>> >>> >> >> > > > > ________________________________________________________________________________
