Page 2 of 2
RE: Pietenpol-List: Power setting question.
Posted: Thu Feb 28, 2008 6:02 am
Re: Polyurethane glues (Was: Re: Pietenpol-List: Re: Spruce Alternatives)
Posted: Thu Feb 28, 2008 6:39 am
I have both of the Fine Woodworking glue articles scanned as pdf files.The files are approx 1.5 mb and 1 mb in size. I can e-mail a copy to anyone who is interested.Contact me off list.Greg Cardinalgcardinal(at)comcast.net>> There are some interesting pages about glues at > http://www.roymech.co.uk/Useful_Tables/ ... html#Types and > the links.>________________________________________________________________________________
Re: Pietenpol-List: Power setting question.
Posted: Thu Feb 28, 2008 6:47 am
Original Posted By: "Tim"
Tim,It won't be a problem. Pietenpols have flown with more than 100 hp.Greg Cardinal----- Original Message -----
Posted: Thu Feb 28, 2008 6:58 am
Posted: Thu Feb 28, 2008 7:27 am
Posted: Thu Feb 28, 2008 7:40 am
Posted: Thu Feb 28, 2008 8:33 am
Re: Pietenpol-List: Spruce Alternatives
Posted: Thu Feb 28, 2008 9:23 pm
CliffInstead of having a one ply grain with only one orientation of the grain, stacking plys with grain running in different directions would add strength and limit the possibility of warping.. Same principal as plywood vs regular board. Dick ----- Original Message -----
Re: Pietenpol-List: Another newbie looking for advise
Posted: Thu Feb 28, 2008 10:05 pm
Original Posted By: Glenn Thomas
Hi Glenn,Once again, thank you!I ordered the 1/2 x 1/2 with my capstrip order to do the nose piece; I got 6', sounds like I'll be ordering more ! I was hoping that was what you used as my jig in now finished and that was my last question, for this week.I live in Wisconsin, about an hour and a half from Brodhead and an hour and 15 from Oshkosh. I know, so close to Mecca. The list has been incredible, and the info you have given me is a great example. I have found several builders in my area but have yet to meet any personally. I hope to change that in the near future.No need to apologize for the 4 paragraph answer. I think I'm doing 3 paragraphs to say thank you. I will make my first rib this week and it is exciting to finally get underway. And thanks for the open invitation to ask questions, I know I have many to come.Thanks again Glenn, I'm sure we will meet this summer at either Brodhead or Oshkosh. Also, I'll bet we will e-mail again soon !Jim ----- Original Message -----
Re: Pietenpol-List: Re: Fuel Sending Ideas
Posted: Thu Feb 28, 2008 10:13 pm
Subject: Re: Pietenpol-List: Re: Fuel Sending Ideasgood project, but looks like you can only install the float when the gauge is directly below the filler neck??So, can you epoxy the gauge fitting into the tank bottom or is that a weld requirement?In a message dated 2/28/2008 7:03:38 P.M. Central Standard Time, kmheidecpo(at)yahoo.com writes:Hey Mike,I insert the float with my hands into the tanks and then fish it up into the opening. Then I screw the sight gauge into place. I will epoxy the red cap on the top which prevents it from falling all the way into the tank. I have around 2.5 to 3.0 gallons left when empty.KenMikeD wrote:--> Pietenpol-List message posted by: "MikeD" kmheidecpo(at)yahoo.com wrote:> Fellow Pieter's.....> > Or should I say Pieter fellows?...either way, here is some of the hardware and results of building and testing for a new fuel sight gauge on my tank. Remember, this is a test sample to see what works...this is a "professional" please do not attempt to preform this at home or in your work shop! tee-hee-hee> > I started with a bunch of items from the local hardware store. After creating a vision, I narrowed it down to the aluminum driveway marker, copperwater knocker, a few copper reducers and two brass sleeves to provide a smoothinside surface to work with.> > I tested this in a bucket of water and found the small aluminum canister of Axe works great but not strong enough for my liking. Therefore, I have created another aluminum shaft with a 2oz can of WD-40 (not yet finished). Afterdraining the contents, drilling, and epoxy the aluminum shaft in place, this set up works very nice. No binding and smooth shaft movement...> > Anyone else experiment with tank gages other than the wire. With my eyesight, The red cap is easily seen from a distance and the gauge hole is slightlyoff center so I can see the gauge when a passenger is in the front cockpit. Once I have tested this system further, I'll show a photo of the whole -da Vinci/John Gillespie Magee ____________________________________Be a better friend, newshound, and (http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-plea ... 0000002598)________________________________________________________________________________
RE: Pietenpol-List: Another newbie looking for advise
Posted: Fri Feb 29, 2008 5:46 am
Posted: Fri Feb 29, 2008 5:59 am
Original Posted By: Tim
RE: Pietenpol-List: Spruce Alternatives
Posted: Fri Feb 29, 2008 6:54 am
Cliff,I=92m not sure where you are going with this argument. AC43.13 specificallystates that =93=85solid spars may be replaced with laminated ones or viceversa=85=94 There is no mention of switching grain direction when doing laminations; soif one prefers to switch direction ' it=92s OK; if one prefers not to switchdirection, it=92s OK, too.There may be some validity to your argument, I don=92t know, but apparentlythe FAA isn=92t concerned, which should be good enough for any of us.Gary Boothe Cool, CA _____
Posted: Sun Mar 02, 2008 12:33 pm
To:pietenpol-list(at)matronics.comSubject: Re: Pietenpol-List: Another newbie looking for adviseRight now the forum is a little busy with an unusually large wave of builders andopinions. That is an understatement, I have never seen this newsgroup so busy in the fouryears I have been tuning in. This years Broadhead get together should be a worldsrecord (I hope). For all you newer Pietenpolers out there who have neverbeen to Broadhead, I guarantee you will learn more in one day seeing flying Piets(and maybe even riding in one) and talking to successful builders than youwill in a year of reading Internet groups and staring at the plans (and you mayeven have some fun).RickRick HollandObjectAge Ltd.________________________________________________________________________________Date: Mon, 03 Mar 2008 00:24:20 -0800
Posted: Sun Mar 02, 2008 10:15 pm
Original Posted By: "=?utf-8?B?Sm9obiBSZWNpbmU=?="
I have to disagree, what makes the box beam better is using plywoodthat has grain orientation running 45 degrees with the parallel grain.This puts wood fibers in tension in shear which makes a stronger beam.Can be built lighter and stronger. Lamination of wood have the same strength asa perfect piece of wood that has no flaws. Or it could dependon how the laminate is done.--------RussellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Another newbie looking for advise
Posted: Sun Mar 02, 2008 10:47 pm
I plan to be there. Who knows maybe even get a ride this time JohnSent from my Verizon Wireless BlackBerry-----Original Message-----
Posted: Mon Mar 03, 2008 2:58 am
Now a question, regular Finnish birch, phenol resin glue, 1/8 (3 mm)cut in strips diagonally across the plywood board at spars width.this would make all grain run at 45 degree, thats glued to 1' by 1 1/4'fir cap stripe, then another regular 90 degree piece on the otherside, the splices would be scarfed to 1' and glued. anyone see anything wrong with this? There would be some waste material howeverthis could be used else where as gussets. Two sides of the box sparone regular grain and one that has all grain with a 45 degree orientation.There would be webbing at spar locations and double width at crossbrace points.--------RussellRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Posted: Mon Mar 03, 2008 6:21 am
Since we obviously have a social crowd who likes to visit, I extend a welcome to any visitors who ever get to the Cincinatti, Louisville or Lexington area. My piet is a Ford, straight gear, 90% done, engine running on stand. I am just south of Cincinatti off the 75/71 split, 1.25 hours from Louisville or Lexington.I would second the plug for Brodhead. Since we have so many new people who havn't been, let me think of a good way to put this...YOU MUST COME TO BRODHEAD!!!It is truly a wonderful place, filled with wonderful people, and the wonderful airplanes we love. You can see ten different ways builders have done things, talk to them, spend all day watching them fly, catch a ride or two and take pictures galore. It is also a great way to cement the comradarie which has always been rather unique to the Piet crowd, and it'll give you that boost to get you through another year of building. It's kind of like the Piet builders yearly shot in the arm to keep running towards the finish line!!Douwe________________________________________________________________________________Subject: RE: Pietenpol-List: Power setting question.Date: Mon, 3 Mar 2008 07:43:11 -0500
Posted: Mon Mar 03, 2008 6:45 am
Re: Pietenpol-List: visitors welcome and Brodhead
Posted: Mon Mar 03, 2008 7:00 am
And don't forget to wear a nametag at Brodhead........Greg Cardinal ----- Original Message -----
Posted: Mon Mar 03, 2008 11:39 am
Posted: Mon Mar 03, 2008 12:34 pm
Original Posted By: "bhassel"
Not that I'll have much of a chance to make it all the way up to Brodhead, butwhen is it this year?BobSanta Fe, NMRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Spruce Alternatives
Posted: Mon Mar 03, 2008 1:13 pm
I've worked some with metal and some with composites/fiberglass/MSG but this woodstuff is new to me. I'd like to find a workable solution because of the expense of the spruce and gettingit all the way down here in the southwest. Of course living in the desertsouthwest means aircraft wood is not a naturally occurring entity.I'm not sure I can keep all of my brain cells aligned in this discussion but pleasedon't let it stop. If I could go down to my local Lowe's and find reasonablypriced/acceptable wood (still learning that one as well) I'd love it!BobSanta Fe, NMRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 3 Mar 2008 11:20:36 -0800 (PST)
RE: Pietenpol-List: Re: Spruce Alternatives
Posted: Mon Mar 03, 2008 1:25 pm
Pietenpol-List: Re: visitors welcome and Brodhead
Posted: Mon Mar 03, 2008 1:36 pm
thanks!I noticed the new site for the BPA on there as well - two new favorites!BobSanta Fe, NMRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 03 Mar 2008 14:36:02 -0500
Posted: Mon Mar 03, 2008 2:17 pm
Posted: Mon Mar 03, 2008 2:36 pm
Posted: Mon Mar 03, 2008 5:22 pm
Thanks Jack for saving me the effort of typing up that reply. I whole-heartedlyagree with what you are saying. My aircraft grade spruce has cost me about$1,100 over 6 years. I have more then that in wheels (I have 3 sets, 2 that weretotally inadequate(I was trying to save money using an alternative) and thereal ones on the plane). Its 1/4th the cost of my engine and probably cheaperthen the cost of covering materials. Did I forget to say how much the strutsare going to cost? Some of you need to take a look at the cost of turn bucklesand shackles. You are going to need about 30 turnbuckles and 10 to 15 shackles.Kind of makes the cost of spruce look better. There is a lot more costinvolved then just price of spruce.Chris, cutting up Jack's soap box for the wood.--------Chris TracyWestCoastPiet.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 3 Mar 2008 15:34:17 -0800
Re: [!! SPAM] Pietenpol-List: Finished wieghts of Spruce Piets vs. Douglas
Posted: Mon Mar 03, 2008 5:34 pm
Posted: Mon Mar 03, 2008 7:57 pm
I think one of the great things about the Piet is the idea that you can use localcomponents and build a safe, reliable and affordable aircraft - sort of likeSt. Bernard did. I know there are some incredible looking Piets out there, I've seen the picturesand I drool. But the truth is that cost is a huge factor for me; so is safetyand so is fun. The ability to find local suppliers helps reduce cost; whypay for shipping across country on anything that I don't have to. If I have tospend the money I'd rather have it on the plane rather than on someone else'struck. Any dollars I can save anywhere can go somewhere else including thegas tank. I don't have a lot of dollars; they are all valuable. In the end I'llprobably just order from ACS or Wicks but honestly it'll be because of mylevel of knowledge about picking out good wood rather than some other reason.I may not build a beautiful Lindy Award Winner like MikeC and others, it may evenbe ugly compared to some of the jewels that I've seen pictures of, but my goalis affordable flight (I know - oxy-moron - or perhaps straight moron [Laughing]).Thanks for the input everyone - this is a great forum for a super aircraft. Ilove the differing ideas - they all make me think and learn! It's great to haveeverything put into perspective and to scratch a brain cell every once in awhile.BobSanta Fe, NMRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 03 Mar 2008 21:01:54 -0500
Posted: Mon Mar 03, 2008 8:47 pm
Some one wrote, go down to Lowe's and get your wood, thats exactly what I intendto do, for wood working practice I'm building a motorcycle trailer outof Douglas fir that I purchased from the high grade lumber section,you can take you time and select the best boards, some of the grain thats next to the edge runs the entire 18 feet along the edge with norun out. Eight growth rings per inch, no pitch pockets and it is verystrong, I love this forum I've found a home. Feel free to speak yourmind to me at any time it could save my life.Thanks,--------RussellRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Posted: Mon Mar 03, 2008 10:22 pm
Bob,Being VERY picky, I have found usable poplar at Lowe's.Gary Boothe Cool, CA WW Conversion 90% done, Working on Tail Group-----Original Message-----
Posted: Tue Mar 04, 2008 1:18 am
Thnaks--------RussellRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Posted: Tue Mar 04, 2008 7:37 am
Posted: Fri Apr 28, 2017 9:32 pm
> Subject: RE: Pietenpol-List: Spruce Alternatives>>> Hi all,> This poplar question has me wondering. First of all, I could be all> wet, but...After checking all of Tony's books and other EAA> publications, I can't find any reference to poplar being a suitable> substitution to spruce for structural applications. If it is, great!> Just wanted to be sure someone has checked it out.> Jack> www.textors.com>>________________________________________________________________________________Date: Sat, 23 Feb 2008 12:01:26 -0700
