Page 2 of 2
RE: RE: Pietenpol-List: Piet List Directory
Posted: Tue Dec 28, 2010 2:18 pm
Original Posted By: macz(at)peak.org
KM my airplane has yet to be assembled. Putting the finishing touches on the gearnow. Then I will assemble and finish the struts and brace cables. No coveringon anything yet.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers doneusing Lycoming O-235Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 28 Dec 2010 14:17:15 -0800 (PST)Subject: RE: RE: Pietenpol-List: Piet List Directory
Re: Pietenpol-List: Re: Cable Tension
Posted: Tue Dec 28, 2010 5:48 pm
Original Posted By: "K5YAC"
It came today. Read the article about cables and it didn't help much. I need a set of what the article calls 'manufacturer's tolerances'. I guess I'll use Jack Philips' system.----- Original Message -----
> RE: Pietenpol-List: wood legs
> Subject: RE: Pietenpol-List: wood legs>>> Greg> I hope you tighten that bolt for the wing strut and turn it over in the> process
> Barry>> -----Original Message-----
Pietenpol-List: Re: wood legs
> --> Pietenpol-List message posted> by: "Jerry Dotson" > > The 3/8 rod goes all the way through. I glued up the struts> 5 layers and 4 layers. The I milled a 3/8 half round> groove from end to end. Then laminated the 2 pieces around> the rod with T-88. The 5 layer part will be trailing edge.> > --------> Jerry Dotson> 59 Daniel Johnson Rd> Baker, FL 32531> > Started building NX510JD July, 2009> wing, tailfeathers done> using Lycoming O-235> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 806#324806> > > > > > > > Lists This Month --> Some AWESOME FREE Gifts!)> Raiser. Click on> out more about> Gifts provided>
www.aeroelectric.com>
www.buildersbooks.com>
www.homebuilthelp.com> -Matt> Dralle, List Admin.> Email Forum -> FAQ,> - MATRONICS WEB FORUMS -> > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: wood legs
