Page 2 of 2
Re: Pietenpol-List: Re: A Pietenpol named Mr. Sam
Posted: Thu Apr 25, 2013 9:38 pm
Original Posted By: "tools"
HI MikeMy belts attach to the tail wheel with a cable that goes forward to about where the bell crank is. Both sides of the seat belts attach and the shoulder harness attaches to the same point. If anyone is interested I can send a couple of pics.Dick N.----- Original Message -----
Posted: Fri Apr 26, 2013 7:27 am
Congratulations Bill!Great number choice too ;)--------Earl BrownI may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: A Pietenpol named Mr. Sam
Posted: Sat Apr 27, 2013 3:54 pm
Original Posted By: Jim Boyer
Hi JimYes the prop is apparantly the only damage at this point. I am giving it a very strong annual right now and havent found anything else other than a loose nut on the tail wheel.Later Dick N. ----- Original Message -----
RE: Pietenpol-List: Re: A Pietenpol named Mr. Sam
Posted: Sat Apr 27, 2013 5:25 pm
How about that loose nut in the cockpit?Sorry Dick - couldn't resist such an opening. You gonna have it allrepaired in time to fly it to Brodhead?Jack PhillipsNX899JPSmith Mountain Lake, Virginia _____
Posted: Sat Apr 27, 2013 10:34 pm
Hi JackYes I will, Hopefully Culver Propellers will come thru with my prop. If not I have a spare.Dick ----- Original Message -----
Posted: Mon Apr 29, 2013 9:30 am
Original Posted By: DandD Boyd
Sparks! Yes, you should see them coming out of a Kenner on the Fleet. What ashow! I wondering what the O-200 will look like in Mr. Sam....--------Jim McWhorterN687MB (New Owner)Culpeper, VA KCJRRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 29 Apr 2013 09:33:08 -0500Subject: Re: Pietenpol-List: Re: A Pietenpol named Mr. Sam
Posted: Mon Apr 29, 2013 10:17 am
Original Posted By: norm
Posted: Fri May 03, 2013 4:19 pm
Original Posted By: airlion2(at)gmail.com
Subject: Re: Pietenpol-List: Re: A Pietenpol named Mr. Sam UNCLASSIFIED Clif, How tall are you? I am 5ft 7.5 in. I am build normally, not with a clownishlyshort torso ;+) I am looking at slightly modifying my plane to have a similarsetup to yours. BTW Great pictures, they tell me a lot.Blue Skies,Steve DOn 04/26/13, Clif Dawson wrote:> Being a bit short torso'd,well, maybe short all over.> I was 5' 8 1/2" when younger but now seem to> have lost an inch of that somehow. Anyway,this> means that my shoulders don't stick up above> the turtle deck. THAT means my shoulder> harness can safely route through the top edge of> the seat back. I have cabled the two straps into> one that goes back to the tail post. The rod that> fits is 12" dia 6061-T6 alum. The black bits on the> tail rod are rubber tube lengths to keep the cable> centered.> If you need them higher and also don't want to cut> into the back then possibly my first idea might> give you a start. That's the drawing. The bumps> were going to be fabric covered balsa.> > Clif> > >I've seen several Piets and they do NOT have shoulder harnesses - just seatbelts. Does anyone use a 4-point harness in the back seat or is it tradition touse only a lap belt?> since the seat back is built-in to the frame - there will have to be some seriouswood cutting to install the shoulder harness.> .> >Jim McWhorter> >N687MB (New Owner)> >Culpeper, VA KCJRUNCLASSIFIED________________________________________________________________________________
Re: Pietenpol-List: Logbook
Posted: Fri May 03, 2013 7:13 pm
Hey all. What kind of notations do I have to log in my logbook after my completerebuild. Do I just treat it as an annual and note the repairs made ? See youin Brodhead. Cheers Gardiner ( airlion2(at)gmail.com> > > --------> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 833#399833> > > > > Attachments: > > http://forums.matronics.com//files/img_2960_205.jpg> http://forums.matronics.com//files/img_2959_229.jpg> > > > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Logbook
Posted: Fri May 03, 2013 7:24 pm
Gardiner and others the last few days I have not been able to access the attachmentlinks, I receive file not found 404... Happening to others?Sent from my iPadJack TextorOn May 3, 2013, at 7:13 PM, airlion2(at)gmail.com wrote:> > Hey all. What kind of notations do I have to log in my logbook after my completerebuild. Do I just treat it as an annual and note the repairs made ? See youin Brodhead. Cheers Gardiner ( airlion2(at)gmail.com> > > > > > >> >> -------->> >> >> >> >> Read this topic online here:>> >> http://forums.matronics.com/viewtopic.p ... 833#399833>> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/img_2960_205.jpg>> http://forums.matronics.com//files/img_2959_229.jpg> > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Logbook
Pietenpol-List: Re: Logbook
Posted: Fri May 03, 2013 7:36 pm
Me too.Sent from my iPhoneOn May 3, 2013, at 5:24 PM, Jack wrote:> > Gardiner and others the last few days I have not been able to access the attachmentlinks, I receive file not found 404... Happening to others?> > Sent from my iPad> Jack Textor> > On May 3, 2013, at 7:13 PM, airlion2(at)gmail.com wrote:> >> >> Hey all. What kind of notations do I have to log in my logbook after my completerebuild. Do I just treat it as an annual and note the repairs made ? Seeyou in Brodhead. Cheers Gardiner ( airlion2(at)gmail.com>> >> >> >> >> >> >>> >>> -------->>> >>> >>> >>> >>> Read this topic online here:>>> >>> http://forums.matronics.com/viewtopic.p ... 833#399833>>> >>> >>> >>> >>> Attachments: >>> >>> http://forums.matronics.com//files/img_2960_205.jpg>>> http://forums.matronics.com//files/img_2959_229.jpg> > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Logbook
Posted: Fri May 03, 2013 8:03 pm
As far as I know, that's all that is required. Didn't change anything from originaldid ya, like different motor or something?Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Logbook
Posted: Fri May 03, 2013 8:22 pm
That's all you need to do, Gardiner.Since enough time has elapsed to requireanother Condition Inspection, do the inspection noting all the repairs made.Sign it off as a normal inspection (you do have the Repairman's Certificate,don't you?).Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Posted: Thu May 16, 2013 8:04 am
Original Posted By: "Fun2av8"
(1) I am new at this experimental stuff. (2) With the original Piet powered at 65hp - My 100hp O-200 is most likely a bitmuch for the airframe's original design (3) I am one to error way on the side of caution.(4) I am going to adjust my V-speeds to match the Piet website - I like the ideaof being very conservative with respect to pushing structural limits.(5) I am not in a hurry - the journey is the fun part! Low and Slow Rocks!Thanks so much for the info.--------Jim McWhorterN687MB (New Owner)Culpeper, VA KCJRRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: A Pietenpol named Mr. Sam
Posted: Thu May 16, 2013 9:07 am
Lesson Learned the Hard Way .....I am having paperwork issues with Mr. Sam. Thanks so much to the local FSDO -I have recovered some of the missing documents. Still working on issues suchas the Phase II signoff which is not in the temporary logs. When the originallogs are found, I am sure that the Phase II signoff as well as many other thingsI need will be in them.Paper can be lost or destroyed. PDFs live for ever. I am scanning every pieceof paper associated with Mr. Sam into PDFs. I won't go thru this pain again.--------Jim McWhorterN687MB (New Owner)Culpeper, VA KCJRRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: A Pietenpol named Mr. Sam
Posted: Thu May 16, 2013 9:46 am
Jim,Perhaps the local FSDO already did this for you. Go to WWW.FAA.gov and order theCD from the FAA that has all paperwork that has ever been created for yourairplane. I did it for mine and was very surprised at everything that was on it.Turns out I was missing stuff too and dad and I built the darn thing. Theplane has never our family. If I remember correctly, it is only 6 bucks andI received it in less than two weeks. Highly recommended. Happy landings,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: A Pietenpol named Mr. Sam
Posted: Thu May 16, 2013 10:08 am
I ordered the CD this morning. But, I am still scanning everything to PDF andsaving it to a rewrite able DVD. This includes the plans and pictures.--------Jim McWhorterN687MB (New Owner)Culpeper, VA KCJRRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: A Pietenpol named Mr. Sam
Posted: Sun Jun 02, 2013 8:13 pm
Original Posted By: "M. Zeke Zechini"
Well timed question for me too... I just finished the second coat of varnish (man-o-warspar varnish) on the exposed areas of my fuse, and one coat on the rearof the fuse.Even after sitting for a week, the "stirred well before application" second coatseems soft and pills up with a light sanding (102 degrees today so it shouldbe 'cured' after a week I'd guess). First coat is hard and dry... Second coatseems like I could scratch it easily, and it is the floor of the fuse inside.Can I use West System Epoxy to make a final coat over the varnish, or would thatprevent some kind of 'curing' that I am unaware of with the varnish...? I amusing the West Systems 105 and 205 to build the plane and it is outstandingstuff. I spoke to a friend at church that built an all wood Barracuda and usedWest Systems for his sealing finish and really likes it, but I am afraid of makinga mess if I paint over the varnish with it and it needs a month or somethingto finally set.Thanks!Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: A Pietenpol named Mr. Sam
Posted: Sun Jun 02, 2013 9:29 pm
My Comanche co-owner still a member of 186. I want to borrow their scales to doW&B...Sent from my iPadOn Apr 20, 2013, at 9:14 PM, "Fun2av8" wrote:> > Absorbing .... Lots of great stuff. As luck would have it EAA Chapter 186was out at KCJR today and will be there again tomorrow. I'm going to go introducemyself. Their website has a really great tutorial on W&B that reads wellwith Tools comments.> > Got homework to do ... :-)> > --------> Jim McWhorter> N687MB (New Owner)> Culpeper, VA KCJR> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 021#399021> > > > > > > > > > ________________________________________________________________________________
> To: pietenpol-list(at)matronics.com> > > FYI> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 393#399393> > > > > Attachments: > > http://forums.matronics.com//files/tele ... ne_177.jpg> > > > ============================================> > > ________________________________________________________________________________Subject: Pietenpol-List: Re: A Pietenpol named Mr. Sam
