Page 2 of 2
Pietenpol-List: Re: squirrelly on the gear
Posted: Mon Jun 24, 2013 7:41 pm
There's a difference between metric swiveling and US Standard swiveling.GarySent from my iPhoneOn Jun 24, 2013, at 5:35 PM, "Bill Church" wrote:> > That sure looks like a swivelling tailwheel to me.> But what do I know.> > BC> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 357#403357> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: squirrelly on the gear
Posted: Tue Jun 25, 2013 7:16 am
Hi Bill,Gary is right. It is a special US Standard Non-swivel tailwheel fork. Really,it is a non-swivel. I just have a lot of sag in my chains which allows it toturn 90 degrees to either side. It works out very well for me and allows forturning in tight areas even without brakes. Oh, no shimmies either. Come tothe west coast Piet gathering next year and I will demonstrate it for you. Cheers,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: ELT requirement
Posted: Tue Jun 25, 2013 9:11 am
Original Posted By:> ----- Original Message ----- "Ben Charvet"
Subject: Re: Pietenpol-List: ELT requirement UNCLASSIFIEDI would really suggest getting the ELT that uses coppertop D cell batteries. Theycan save you a significant amount of money over the years.Blue Skies,Steve D On 06/24/13, "l.morlock" wrote:> > I ended up putting the ELT unit under the pilot's seat and the ground plane &antenna just behind the pilot's seatback, similar to Jack's.> > Whether an ELT is required seems to be up to your individual DAR's interpretationof the FAR. Mine said I am not conducting training, so I need an ELT regardlessof how close or far I am from the airport. Also, I tried to say it waspart of the design and testing of the aircraft, but no joy on that one either.> > I bought a new ELT from ACS for $199.. Had access to older ones, but by the timeI modified them and renewed batteries, it was about as cheap to get the newone.> > Larry>
Posted: Tue Jun 25, 2013 9:17 am
Re: Pietenpol-List: Re: What oil in a Corvair?
Posted: Tue Jun 25, 2013 3:47 pm
Could be I'm missing something here, but if your oil temps are running over 400F,you probably have a problem; could that actually be 220?--------Tom KreinerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: What oil in a Corvair?
Posted: Tue Jun 25, 2013 5:11 pm
Tom. I am using rotella. 15 /40 and my temps are 220 to 240, cheers, gardiner"Sent from my iPadOn Jun 25, 2013, at 4:47 PM, "tkreiner" wrote:> > Could be I'm missing something here, but if your oil temps are running over 400F,you probably have a problem; could that actually be 220?> > --------> Tom Kreiner> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 421#403421> > > > > > > > > > ________________________________________________________________________________Date: Tue, 25 Jun 2013 17:27:50 -0700 (PDT)
