Pietenpol-List: Piet project
Posted: Wed Apr 30, 1997 9:25 am
Original Posted By: D.BELLISSIMO(at)littonlsl.com (BELLISSIMO, DOMENIC)
Good a.m., gentlemen,Tax season is past, I'm back to work on my ship! I have all but finished my propeller. It is laminated of oak, pretty much toHoward Henderson's plans. All that is left is re-balancing it aftervarnishing, and polishing out the varnish. I used Epifanes varnish on it. Wonderful stuff and makes a BEAUTIFUL finish. I cut out my trailing edges last night. This data might help someone. Theywere cut from 3/4" spruce stock. I ripped some sticks 1 3/8" wide. Then Iset the blade angle on my table saw to 12 degrees and the rip fence 3/16"from the base of the blade. This enabled me split these strips (turned onedge) into two triangular trailing edge pieces with little waste. I thensimply ripped the skinny side of these strips off to give a total width of 11/4". They came out beautifully.I hope to start covering about June 1. 'All' that is left is to assemble thewing panels and associated struts and cables. Ha!See you gentlemen later.John________________________________________________________________________________
Pietenpol-List: Re: Piet project
Posted: Wed Apr 30, 1997 10:12 pm
Original Posted By: JGreenlee(at)aol.com
>Good a.m., gentlemen,>>Tax season is past, I'm back to work on my ship! >>I have all but finished my propeller. It is laminated of oak, pretty much to>Howard Henderson's plans. John,I am also interested in making a wood prop. I have lots of oak. Where didyou get the plans? Do you use a prop making "machine"?Thanks,Ted Brousseau/APFnfn00979(at)gator.naples.netSunny SW Florida________________________________________________________________________________
Posted: Thu May 01, 1997 9:02 am
Ted,See my last post re: machine.Grant wrote up some nice instructions re: Howard Henderson's props. I got adrawing from Howard.I also recommend Eric Clutton's book on prop carving. I think EAA has it.John________________________________________________________________________________
Posted: Wed Oct 18, 2006 2:00 pm
To:Subject: Pietenpol-List: Piet projectJohn: I have a fusealoge and all the wing ribs for sale. I purchased a flying Piet fromMrs Don Hicks in Alabama a few months back and have no need for them. Let meknow what you have to trade? Also it takes 5G's to set off an ELT. ________________________________________________________________________________
Re: Pietenpol-List: Piet project
Posted: Wed Oct 18, 2006 7:00 pm
Original Posted By: Amsafetyc(at)aol.com
John:I have a fusealoge and all the wing ribs for sale. I purchased a flying Piet from Mrs Don Hicks in Alabama a few months back and have no need for them. Let me know what you have to trade?Also it takes 5G's to set off an ELT.Chet________________________________________________________________________________Subject: Re: Pietenpol-List: Piet project
Posted: Wed Oct 18, 2006 7:25 pm
Original Posted By: "Chet's Mail"
Chet, Let's discuss, contact me direct at amsafetyc(at)aol.com we can exchange info privately.JohnSent from my Verizon Wireless BlackBerry -----Original Message-----
Posted: Thu Oct 19, 2006 6:50 am
Original Posted By: Chet's Mail
Chet,Have you flown your new plane yet? You really bought one of the nicest Piets around.Gene ----- Original Message -----
RE: Pietenpol-List: Piet project
Posted: Thu Oct 19, 2006 10:15 am
If John's not interested may I inquire as to the project.Bob -----Original Message-----
Posted: Thu Oct 19, 2006 12:00 pm
Original Posted By: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of AMsafetyC(at)aol.com
To:Subject: RE: Pietenpol-List: Piet projectThanks! I do not want to be offensive. Can you tell I'm a type A?
Posted: Thu Oct 19, 2006 2:12 pm
Original Posted By: Gene &
To:Subject: Re: Pietenpol-List: Piet projectGene: No I have just found out what the brake problem was, and have corrected that. I'm still having problems getting the A started, I'm not sure what to do there,as I have tryed several combinations. Also I just received my paper work from the Fed's last week, So if all goes wellthis weekend and the weather holds I may get to fly here for the first time.Chet ----- Original Message -----
Posted: Thu Oct 19, 2006 2:55 pm
Original Posted By: "Robert Gow"
Subject: Re: Pietenpol-List: Piet projectBob FYII have expressed an interest in the project and am awaiting information from Chet to open dialogue. I am hoping to hear from him soon whereby I will be better suited to continue the process or allow the opportunity to pass me by.I look forward to hearing something soon.But have no problem with your expressing your interests also. John________________________________________________________________________________
Posted: Thu Oct 19, 2006 4:00 pm
Thanks! I do not want to be offensive. Can you tell I'm a type A? :-)Bob -----Original Message-----
Posted: Thu Oct 19, 2006 7:12 pm
Original Posted By: Gene & Tammy
Gene:No I have just found out what the brake problem was, and have corrected that.I'm still having problems getting the A started, I'm not sure what to do there, as I have tryed several combinations.Also I just received my paper work from the Fed's last week, So if all goes well this weekend and the weather holds I may get to fly here for the first time.Chet ----- Original Message -----
Posted: Thu Oct 19, 2006 7:19 pm
Not a problem, I have done the same and quite understand!JohnSent from my Verizon Wireless BlackBerry -----Original Message-----
Posted: Thu Oct 19, 2006 7:30 pm
Chet,Awaiting your contact info to discuss your project for sale.Please adviseJohnSent from my Verizon Wireless BlackBerry -----Original Message-----
Posted: Sun Oct 22, 2006 1:58 pm
I have two Piet projects for sale. One was assembled by Ron Lustig formerly of Chicago. My husband Carl Vought bought Ron's project about three years ago and then decided to start from scratch on a Piet of his own. Carl died July 10 of this year. I'm eager to sell each of the projects.Contact me at 256-883-9869.Barbara Vought ----- Original Message -----
Posted: Sun Oct 22, 2006 8:43 pm
Subject: Re: Pietenpol-List: Piet projectBarbara,Sorry to bother you again, but more questions on the two projects:Where are you located and what's included in each of the projects, how close are they to being completed. I am interested can you provide pics and do you have a builders log from your hubby's build. Why did he decide not to continue with the project he bought? Was hubby a big man and did he build for his size or did he stay strictly to pietenpol plansThanksJohn________________________________________________________________________________
Posted: Sun Oct 22, 2006 11:45 pm
Barbara,Very sad news about Carl. I wish you luck selling the Piets and better timesahead. It can't be easy and I can only imagine what it takes to drive aheadfrom here.Greg Chapmanhttp://
www.mousetrax.com http://www.layer1wireless.com _____
Posted: Mon Oct 23, 2006 7:54 am
I am illiterate when it comes to Piets (and e-mai!). If you can call at 257-883-9869 I can tell you what little I know and refer you to one of Carl's friends who does know . If you send me your snail-mail address I can send you a listing of the parts of one of the planes. They were was assembled by a man in Chicago. Both projects are now located in Huntsville, ALBarbara Vought ----- Original Message -----
Posted: Mon Oct 23, 2006 8:24 am
Sure. Let me know what develops. Are either the "Ford" fuse?Bob. -----Original Message-----
Posted: Mon Oct 23, 2006 3:13 pm
If you have not sold already contact me off-listRobert GowPhone - 705-527-6095Fax - 705-527-6028Cell - 416-434-3393rgow(at)avionicsdesign.cawww.avionicsdesign.ca -----Original Message-----
Posted: Fri Oct 27, 2006 6:09 am
Re: Carl's Piet projects. Call me at 256-883-9869 and I'll put you in touch with our friend Bob who is an engineer/pilot and knows the projects. He can furnish you with photos and answer questions that I cannot.BarbaraVought ----- Original Message -----
