Pietenpol-List: Re: Fir
Posted: Tue May 13, 1997 4:19 pm
Original Posted By: grhans(at)freenet.edmonton.ab.ca
The following is an excerpt from "EAA Aircraft Building Techniques": "If your spruce ship weighs, say 800 lbs. empty you have probablyaround 100-150 lbs. of wood in it. With fir your ship would pick up25-35 lbs more, which isn't very much, all things considered." (Not mywords - just a quote). However, based on the information contained in this excellent guide, I have substituted fir in the seat framing, ailerons and a few other bits and pieces here and there. I do not remember the prices I paid at the time, but definitely cheaper than spruce and due to the smaller individual sizes I was able to cut out excellent pieces as required. By smaller I don't mean reduced dimensions I left everything sized as per plan. Working with fir is a bit more difficult, but when I "cut off one piece twice to find it still an inch too short" it was relatively painless ($). (By the way I'm sure that was the only "errant" cut I madeduring process
Need any fir toothpicks? Gary________________________________________________________________________________
