Pietenpol-List: Landing Gear Toes
Posted: Wed Nov 05, 1997 3:46 pm
> . There is no alignment issue w/ the straight gear> > like you have when you weld up the split gear. It's true from wheel>> > to wheel right away. I hear from those much wiser that a plane> > with wheels pointed in different directions can make it a whole> > different animal. Hopefully others w/ more experience will> > comment. Mike C.> >> >> Taildraggers should be aligned straight or should have a little bit of>> toe out (a couple of degrees). If they are toed in they get really> squirrely.This is correct. The reason is in toed in conditions it is very easyfor the toed in wheel (either if both are toed in) to quickly *very*quickly steer the airplane in to a turn. One may reason well duh,wouldn't a toe out condition cause a turn as well? the answer is YES.The difference is that a toe in turn will tighten because more and moreweight will be place on the toed in wheel until you are tied into aground loop, folding the gear in the process. Toe out will have theopposite effect thus decreasing -to a degree- the tendancy of the tailto swap ends. I know of a Champ that had a real bad habit ofgroundlooping to one side --enough that the pilot-- nor anyone elsewould fly it It was sold in this condition as a lost cause. Beforeflying the new owner blocked, and dropped a plumb bobed the gear andfound that one wheel had toe in of 2-3 degrees on one side and 2-3degrees toe out on the other! In addition the toe out side was a coupleof inches displaced to the rear. After a repair the the plane flew,well, like a CHAMP.No Really!Steve E.________________________________________________________________________________
