Pietenpol-List: fuel tanks
Posted: Sun Nov 09, 1997 9:44 am
Have beeen sending messages for 2.5 weeks with no reply to the group withpeg.mail.Do not see any of the messages on my incoming mail from thegroup,but see all other traffic.This message is being sent with microsoftmail,hope it works. What are most builders using for nose tanks.ie. fiberglass etc. whattype or resin for auto fuel that may contain alcohol etc???(corvair powerwith fuel pump)Want to use center section for storage rather than a fueltank.Thanks for now Doug Hunt________________________________________________________________________________
Pietenpol-List: Re: fuel tanks
Posted: Sun Nov 09, 1997 2:55 pm
Original Posted By: Doug Hunt
doug huntPreferred Customer wrote:> > Have beeen sending messages for 2.5 weeks with no reply to the group with> peg.mail.Do not see any of the messages on my incoming mail from the> group,but see all other traffic.This message is being sent with microsoft> mail,hope it works.> > What are most builders using for nose tanks.ie. fiberglass etc. what> type or resin for auto fuel that may contain alcohol etc???(corvair power> with fuel pump)Want to use center section for storage rather than a fuel> tank.> > Thanks for now Doug HuntWith regard to fuel safe resins, I would talk with the vendors most ofthem have a tech-support line. I have found them very helpful.TTYL Bob Bailey________________________________________________________________________________
Posted: Sun Nov 09, 1997 2:56 pm
Original Posted By:> Robert M. Bailey
Posted: Mon Nov 10, 1997 10:21 am
Original Posted By: dcsBell(at)netcom.ca
doug huntPreferred Customer wrote:> > Have beeen sending messages for 2.5 weeks with no reply to the group with> peg.mail.Do not see any of the messages on my incoming mail from the> group,but see all other traffic.This message is being sent with microsoft> mail,hope it works.> > What are most builders using for nose tanks.ie. fiberglass etc. what> type or resin for auto fuel that may contain alcohol etc???(corvair power> with fuel pump)Want to use center section for storage rather than a fuel> tank.> > Thanks for now Doug HuntHi Doug, Looks like you got through.Either metal or fiberglass will work for a nose tank. Both have beenused sucessfuuly. Your choice. I don't have any experience withfiberglass but I believe Brian Kenny has and I think he used polyester.Tom Bowdler is also using a nose tank. He used galvanized steel and hadit soldered. My engine is also a corvair, but Iremoved the mech. pump.Since I've used the center section (3 piece wing), There is plenty offlow if you use 3/8" OD aluminum fuel line. I measured the flow with thetail 3 feet below the ground level to simulate take-of attitute at 2Min.and 18 seconds. In Canada you must have a minimum of 24 Imperial Gal.flow in above attitude.Regards, Domenico/Toronto________________________________________________________________________________
Posted: Mon Nov 10, 1997 10:23 am
doug huntPreferred Customer wrote:> > Have beeen sending messages for 2.5 weeks with no reply to the group with> peg.mail.Do not see any of the messages on my incoming mail from the> group,but see all other traffic.This message is being sent with microsoft> mail,hope it works.> > What are most builders using for nose tanks.ie. fiberglass etc. what> type or resin for auto fuel that may contain alcohol etc???(corvair power> with fuel pump)Want to use center section for storage rather than a fuel> tank.> > Thanks for now Doug HuntDoug, Just realized your address has VE6zh, Is that your HAM radio callsign?Regards,Domenico/VE3SNV________________________________________________________________________________
Posted: Mon Nov 10, 1997 6:26 pm
Original Posted By:> dcsBell(at)netcom.ca
Posted: Mon Nov 10, 1997 9:11 pm
Original Posted By:> > dcsBell(at)netcom.ca
Doug Hunt wrote:> > ----------
Posted: Thu Nov 11, 1999 6:52 pm
Original Posted By: "kyle ray"
Is anyone using a wing tank and a fuselage tank. If so are you using thewing tank to feed the lower tank?.________________________________________________________________________________
Re: Pietenpol-List: fuel tanks
Posted: Thu Nov 11, 1999 8:26 pm
Original Posted By: Bradley & Lorraine James
Subject: Re: Pietenpol-List: fuel tanksSteve wrote:Yep Im gonna use the wing tank n fuse tank too. I think I will feed thefude tank when it is over half empty/full.Steve writes:> > > Is anyone using a wing tank and a fuselage tank. If so are you using > the> wing tank to feed the lower tank?.> > > > > > > > > Steve W GN-1 builderIHA #6________________________________________________________________________________Date: Fri, 12 Nov 1999 02:49:29 -0500
Posted: Fri Nov 12, 1999 10:14 am
Posted: Fri Nov 12, 1999 5:00 pm
Original Posted By:> Gary Gower
Re: Pietenpol-List: Routed spars.
Posted: Fri Nov 12, 1999 8:47 pm
Original Posted By: Lawrence V Williams
Subject: Pietenpol-List: Routed spars.Steve wrote:Has any of yall routed your spars? How much did you remove. How did yalldo it,/Between ribs or as a unit.SteveSteve W GN-1 builderIHA #6________________________________________________________________________________Date: Fri, 12 Nov 1999 22:20:41 -0500Subject: Re: Pietenpol-List: Routed spars.
Posted: Fri Nov 12, 1999 9:49 pm
Original Posted By: fishin
Posted: Thu Aug 15, 2002 12:48 pm
"Gary McNeel, Jr." wrote:>The guys at the Noon Patrol, building Nieuport 11's, used the>Cabela's tanks. You might try their site.Here are a couple of photos to show what Gary's talking about:
http://www.eaa292.org/noon_patrol/may_0 ... 3.jpgOscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at
http://www.flysquirrel.netMSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide ... __________
Posted: Tue Sep 29, 2009 11:02 am
Tim asked->Is there an epoxy and glass combo that will not only>accommodate avgas and mogas, but mogas with ethanol>(something we should avoid for other reasons, too)>just in case we get some, either by necessity or ignorance?The glass is completely non-reactive with any of thefuels and is not the issue; it's the epoxy resin used inthe layups. Of all the laminating resins available, theonly one that I know of that fills the bill is vinylesterresin and even that *could* have problems if you usedstraight ethanol. At low percentages such as are used inthe wintertime in some states as autogas blend, it shouldnot be a problem.I think all of the other epoxy resins will have problemswith fuels of one blend or the other and that's wherethe problems have come up in the past, particularly whenautogas has been used. The resin can turn gooey and plugup the fuel system, with obvious consequences, or itcan break down and the glass can delaminate. Vinylesteris just about the best for fuel tanks but it has a shortshelf life, terrible odor, and is a bit fussy to use. Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at
http://www.flysquirrel.net ________________________________________________________________________________Date: Tue, 29 Sep 2009 16:01:52 +0000 (UTC)
Posted: Sun Nov 14, 2010 9:09 pm
Original Posted By: "Dangerous Dave"
Fellow Pieter's:=0A-=0AAny chance someone is making the metal parts and pieces-for the Pietenpol as a kit? I seek to find a source whereas these pieces are made with all the features needed to just paint and assemble! So then, what are the chances to finding a source for these parts....slim to none and slim is out of town? Anyone thought about outsourcing these parts and willing to do so?=0A-=0A-=0AKMH=0AFargo, ND=0A-=0ANot not archive.=0A=0A=0A-=0A=0A=0A=0A=0A=0A=0A=0A ________________________________________________________________________________Subject: Pietenpol-List: fuel tanks
RE: Pietenpol-List: Need to order steel
Posted: Tue Nov 16, 2010 9:56 am
Original Posted By: Kringle
Try using the words "materials list" to search the archives. I do recall seeingthat in the last 6 or 7 months.899WT-----Original Message-----
Posted: Tue Nov 16, 2010 9:57 am
Original Posted By: Dan Yocum
Posted: Tue Nov 16, 2010 10:00 am
Order just enough, and no more.Seriously, there is no way anyone can tell you. For one thing, there aremany different sizes required, and vastly different amounts depending onwhich landing gear and which engine you are using. Whatever you calculate,double it. Steel is cheap - shipping it is expensive, and screwing up apart and then having to wait for more steel to arrive because you orderedjust enough is very frustrating.Many of the parts are made of .090" steel 1" wide or 3/4" wide. You can buy4130 strips that are slit-sawn to those widths and that vastly simplifiescutting the parts.Jack PhillipsNX899JPRaleigh, NC-----Original Message-----
Posted: Tue Nov 16, 2010 11:05 am
If you don't live too rural, you may be able to find a metals supplier nearby.It doesn't all have to come from AC Spruce or Wicks. Usually cheaper too. I founda great source in St. Louis, MO, Shapiro Metals on Natural Bridge. They recycle,deal in used materials and also have a great selection of 4130 sheet andtube and 6061 & 2024 aluminum.If you live out in farm country, check with your local tractor and farm equipmentshop for materials. If they have it, they can probably tell you where to findit. Counting shipping, I save over half the price compared to Spruce or Wicks, andI can pop in whenever I need to restock. Wish they had AN turnbuckles.Jeff Wilson899WT(r)St. LouisFuse done, installing controls.Wings done no hardware.-----Original Message-----
Posted: Tue Nov 16, 2010 11:08 am
Since the Stromberg has no effective mixture control, a recommended way to do engineAND fuel shutoff is to have a cable operated valve close to the engine.The theory is that if you use just the ignition to shut down the engine, theunburned fuel can cause flooding/hard starting issues during a quick restart.Also, the float seats can be a source of leaks so an easily usable fuel shutoffof some kind is almost mandatory. A fuel shutoff at the wing tank is alsoa very good idea just in case something catches fire. That eliminates gas asa source of fuel and also isolates the fuel in case of a forced landing. Hookingboth valves to one cockpit control is going to be my choice.Dave AldrichRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: fuel tanks
Pietenpol-List: Re: Fuel Starvation
Posted: Tue Nov 16, 2010 11:43 am
There is enough room for feet,no controls in the front cockpit,no seat belts infront either,mostly for camping gear,food,rifle and will be covered.31 gallontotal with 28 usable should give me 4 hours with my o-235 cruising at 90.6 days to Alaska from Colorado,with any luck.Probably will take 10 daysDave--------Building a PietRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Fuel Starvation
Posted: Tue Nov 16, 2010 11:52 am
Just getting going on my fuel system as well.The wing tank will refill the nosetank.The nose tank will feed the gascolator and the fuel will be pumped via mechanicalengine pump to the MA3A on the O-235.Not much into wondering if I willhave a fuel starvation problem or redoing everything if the was a problem.Dave--------Building a PietRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 16 Nov 2010 10:56:49 -0800 (PST)
Pietenpol-List: Re: Need to order steel
Posted: Tue Nov 16, 2010 1:26 pm
Original Posted By: "Kringle"
I have gotten my 4130 from Metal Supermarket here in SLC, I know theyhave chains stores. I bought the 4130 sheet and they sheared it to thesizes I needed right there for me. BrianSLC-UT________________________________________________________________________________Subject: Pietenpol-List: Re: Need to order steel
Posted: Wed Mar 26, 2014 8:49 am
Both fuel tank locations have worked fine. Here's why I went with a wingtank and like it.1. The fuel is farther from the hot engine and electrics in most"unplanned attitudes" such as upside down or on it's nose, or in case of anengine fire.2. I have heard of too low fuel head pressure/fuel starvation issueswith fuselage tanks, but not with wing tanks. If you're building a big fusetank, it can be tricky to design it so you get the head pressure you need.It can certainly be done, just watch it in all attitudes.3. Fuel overhead or fuel in my lap can both be bad situations, but it'sall dependent on the incident and there's probably no way to foresee.4. zero CG shift from full to empty.5. I like the storage area up front.In view of WW's accident and the very real potential for forward wingdisplacement during a sudden stop, I strongly recommend flexible fuel linesto the tank. When 799B went over, the wing DID move forward about threeinches and my hard lines held fine, but when I rebuilt her, I was sure touse flexible lines.There are certainly pros for fuselage tanks too, but these are the reasons Iwent with a wing tank.Douwe________________________________________________________________________________Subject: Pietenpol-List: Re: fuel tanks
Pietenpol-List: Re: Adding Tank to Wing
Posted: Wed Mar 26, 2014 10:46 am
I can add to several of Douwe's points (his #1 and #2)-1. My airplane has been upside-down. Carb ice, power loss, precautionary off-fieldlanding on rough terrain... a weld broke on the landing gear leg and it wentover on its nose and onto its back. There was no fire, although there wassome fuel loss through the vent on the fuel tank cap. What I'd like to emphasizewith this is the point that William makes about providing some flexure inthe fuel lines and for making the cabane brace connection rigid rather than adjustableonce you've set the wing angle. Examine the photo of my cabane bracesafter the roll-over and you'll see why:
http://www.flysquirrel.net/piets/incident/PB130010.JPG2. The final couple of gallons (about 2.5) in my 16 gallon tank are unusable inthe 3-point or climb attitude. I demonstrated that fact on a x-c where I landedwith about that amount of fuel in the tank and as soon as I eased the taildown, the engine quit. It's simple physics and geometry... liquid doesn't liketo flow uphill ;o) Examine a side shot of my engine, like this one:
http://www.flysquirrel.net/piets/engine ... JPGPicture where the carb float bowl is relative to the bottom of the fuel tank (aninch or two above the horizontal seam in the firewall). So Mikee is right...I don't fly it down into that last 1/4 tank or so.Two more things and I'm done. First, that seam in my firewall was intended tomake the bottom portion removable to provide access to the underside of the fueltank, the front rudder pedals, and anything else up in the forward cockpit.Unfortunately, I forgot about the engine mount bolting on and being in the way,so it's not removable. Sometimes good ideas aren't ;o) Second, I have neverfueled my airplane without using a ladder. I like to be able to see downinto the fuel tank because it's too easy to flood the tank and cowling if I letit get up to the top. It sometimes happens even when I can see down into thetank. So don't think that using a nose tank will eliminate the usefulness ofa ladder for fueling, unless you're a lot taller than I am (5'-9" in high heels).--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Adding Tank to Wing
Posted: Wed Mar 26, 2014 7:43 pm
Original Posted By: "tools"
Graham,Also, like you. An informative, knowledgeable relic. [Wink]--------Semper Fi,Terry HandAthens, GAUSMC, USMCR, ATPBVD DVD PDQ BBQRead this topic online here:
Posted: Wed Mar 26, 2014 7:46 pm
It's been mentioned a bit in the past, but surprisingly hasn't come up in theserecent discussions at all.About point #2. Dick put a 4 gal (or so) header tank in the nose of 2RN. Hisreasoning was (and I'm a big fan, think it's a great idea) that it prevents prettymuch any chance of the engine quitting because of sloshing in the relativelywide and flat wing tank. At 4 gal, it's an hour reserve of fuel if necessary.I got to thinking about it, I've got a shutoff right outside the cockpit wherethe fuel exits the wing tank. If I were to lose my engine and was in the midstof deadsticking it in, wouldn't take but a fraction of a second to reach upand close that, which would be even more insurance against free flowing fuel inthe event of a fuel line rupture due to wing displacement.Like everything, it's a compromise. It does complicate the fuel piping somewhat.However, as 2RN needed some nose weight due to the relatively light A65, thatwas absorbed. Just more food for thought.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 26 Mar 2014 17:47:45 -0700 (PDT)
Pietenpol-List: Re: It's FINALLY a hangar...
Posted: Wed Mar 26, 2014 9:30 pm
N2RN got her tailwheel, horiz and vert stabs, elevators and rudder, WING, and anaileron reinstalled today. FINALLY...For the first time, a big structure is holding an airplane, so it's technicallya hangar I guess.Tomorrow is lots of adjusting wires, controls, cotter keying and safety wiringturnbuckles. Hopefully get the motor running. Early next week should be in annual and ready for flight. The runway finally seemshard enough to fly upon. Been a long haul on this one.[img]
https://us-mg4.mail.yahoo.com/ya/downlo ... x&inline=1[/img]Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: It's FINALLY a hangar...
Posted: Wed Mar 26, 2014 10:46 pm
So cool to see that. Very exciting times. Fingers crossed for the engine run.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:
Posted: Thu Mar 27, 2014 11:47 am
Original Posted By: macz(at)peak.org
> Re: fuel tanks
> > doug huntPreferred Customer wrote:> > > > Have beeen sending messages for 2.5 weeks with no reply to the groupwith> > peg.mail.Do not see any of the messages on my incoming mail from the> > group,but see all other traffic.This message is being sent withmicrosoft> > mail,hope it works.> > > > What are most builders using for nose tanks.ie. fiberglass etc. what> > type or resin for auto fuel that may contain alcohol etc???(corvairpower> > with fuel pump)Want to use center section for storage rather than afuel> > tank.> > > > Thanks for now Doug Hunt> With regard to fuel safe resins, I would talk with the vendors most of> them have a tech-support line. I have found them very helpful.> TTYL Bob Bailey> Thanks for the tip Bob________________________________________________________________________________
> Re: fuel tanks
> > doug huntPreferred Customer wrote:> > > > Have beeen sending messages for 2.5 weeks with no reply to the groupwith> > peg.mail.Do not see any of the messages on my incoming mail from the> > group,but see all other traffic.This message is being sent withmicrosoft> > mail,hope it works.> > > > What are most builders using for nose tanks.ie. fiberglass etc. what> > type or resin for auto fuel that may contain alcohol etc???(corvairpower> > with fuel pump)Want to use center section for storage rather than afuel> > tank.> > > > Thanks for now Doug Hunt> Doug, Just realized your address has VE6zh, Is that your HAM radio call> sign?> Regards,Domenico/VE3SNV Thanks for the reply Domenico,looks like this email program isworking fine.Yes this is my Ham Radio callsign,easy for me to remember HI HI. I wonder what you are using for intake system on yourcorvair,original carbs is what i will be trying,with carb heat box underengine. Is your Piet flying??? Just sent for the precover paperwork on my Piet.---Anotherquestion,what is the position of your landing gear relative to the leading edge of yourwing? Would be interested to hear what the performance of your corvair is likeetc.________________________________________________________________________________
> > Re: fuel tanks
> >> > doug huntPreferred Customer wrote:> > >> > > Have beeen sending messages for 2.5 weeks with no reply to the group> with> > > peg.mail.Do not see any of the messages on my incoming mail from the> > > group,but see all other traffic.This message is being sent with> microsoft> > > mail,hope it works.> > >> > > What are most builders using for nose tanks.ie. fiberglass etc. what> > > type or resin for auto fuel that may contain alcohol etc???(corvair> power> > > with fuel pump)Want to use center section for storage rather than a> fuel> > > tank.> > >> > > Thanks for now Doug Hunt> > Doug, Just realized your address has VE6zh, Is that your HAM radio call> > sign?> > Regards,Domenico/VE3SNV> Thanks for the reply Domenico,looks like this email program is> working fine.> Yes this is my Ham Radio callsign,easy for me to remember HI HI.> I wonder what you are using for intake system on your> corvair,original carbs is what i will be trying,with carb heat box under> engine. Is your Piet flying???> Just sent for the precover paperwork on my Piet.---Another> question,what is> the position of your landing gear relative to the leading edge of your> wing?> Would be interested to hear what the performance of your corvair is like> etc.Hi Doug,Think twice about using original carbs, which would be sticking out intothe cold slip-stream. I'm not sure but you may encounter some icingproblems. I'm using a stromberg carb off an 85 Continental. It's aboutthe size to use since at 2800 RPM the engine H.P. will be about 83.5.My intake (with lots of help from Jack Watson, another builder) consistsof a couple of brass tubes (sink...P-tubes) avail. from the Home depot,an aluminum 'Y', a couple of 90 degree electrical thinwalled conduittubes and a couple of 90 degree elbows. A bracket holds the carb. andconnects to the oil pan (2 exixting pan screws on each side). The'P-tubes are soldered together so that the 1st curve of the 'p' comesout of the carb./bracket and the 2nd changes direction to aft and up.Then the 'Y' is put in place. The thin walled conduit is fitted to the'Y' with conduit connectors(screwed and epoxied in place), then the 90degree elbows are welded to the conduitand screwed down to the intakewhere the original carbs were. This also helps to keep the frontalprofile down. It's the shortest distance posible if an aircraft carb. isused and placed under the engine for safety. This way if you get gasoverflow it will drip down into the cowl and out the bottom instead of posibly causing a fire. BothJack and I have not used the original cooling fan. A presurized cowlshould work nicely if made properly. It's not like we have deserttemperatures here in Canada. The only time you would need to worry aboutengine overheating is when the ambient temp. is so high that theexisting cooling fins cannot disapate enough heat. That is the spreadbetween the engine temp. and pressurized ambient air. Are you also onthe Internet? I'm not flying yet, but I will be in the Spring.Regards, Domenico (VE3SNV)________________________________________________________________________________
> > > > --- Gary Leopold wrote:> > Not to state the obvious, but why not save the weight and complexityand just feed directly from the top tank into the lower and then to theengine with no valve (except the shut off at the firewall)? You'll alwayshave to fuel through the top wing, but you'd do that anyway. Gene> > =====> > > > > > > > ________________________________________________________________________________
