Pietenpol-List: Re: Two questions... -Reply
Posted: Mon Nov 17, 1997 8:46 am
>>> Doug Hunt 11/16/97 06:46pm >>>If you are going to use the corvair engine,i would consider using anadjustable prop such as the "WARP DRIVE" carbon fiber unit .That wayyouwill buy 1 prop,and it can be adjusted to allow max per.of your engine.Ifyou buy a fixed pitch prop and it loads the engine to heavy,you hang it onthe wall and buy another prop,no economy their!.....Doug....."Prop Making for the Amateur" by Eric Clutton, available from the EAA forabout 7 dollars, shows how to make props including how to re-adjust thepitch after the prop has been carved.A good book for anyone's library even if you don't intend to carve yourown.Greg Cardinal________________________________________________________________________________
