Pietenpol-List: New to list
Posted: Wed Nov 19, 1997 7:29 am
Original Posted By: PHIL PECK
Hi, I'm new to the list. ...haven't committed to building, yet but havebeen seriously studing the Piet and trying to decide wheather or not totake the plunge. I was at Broadhead, breifly this year and got some nice pictures. I'mlearning to acetylene weld and learn about wood. (welding seems lesscomplicated
Input for newbie appreciated. ThanksBobby White. N.W. Ar.________________________________________________________________________________
Pietenpol-List: Re: New to list
Posted: Wed Nov 19, 1997 6:51 pm
Original Posted By: dcsBell(at)netcom.ca
Bobby White wrote:> > Hi, I'm new to the list. ...haven't committed to building, yet but have> been seriously studing the Piet and trying to decide wheather or not to> take the plunge.> I was at Broadhead, breifly this year and got some nice pictures. I'm> learning to acetylene weld and learn about wood. (welding seems less> complicated
Input for newbie appreciated. Thanks> Bobby White. N.W. Ar.Go ahead take the plunge. You won't regret it.Domenico/Toronto________________________________________________________________________________
Posted: Sat Feb 24, 2007 4:48 am
Original Posted By: "GlennThomas(at)flyingwood.com"
My name is Wayne Poole and I live in Denham Springs, Louisiana. My brotherand I have a GN-1 with a Continental 0-200 that is about 95% complete.We're planningto use a J-3 type cowling and I'm trying to find the nose bowl bracketsthat mount on the front of the engine. I'm told that the brackets from Wag-aeroand Univair are for a 65hp Continental and will not fit an 0-200. Does anyoneon the list know where I can locate them or if anyone has drawings of bracketsso I can fabricate some?Wayne Pooledxechkn(at)earthlink.netEarthLink Revolves Around You.________________________________________________________________________________
Re: Pietenpol-List: Flying again.
Posted: Sat Feb 24, 2007 8:09 am
Glad to see that you and the plane are back in the air again.Always nice to hear about another finished project going into service!Glenn W. ThomasStorrs, CThttp://www.flyingwood.com----- Original Message -----
Re: Pietenpol-List: Lower motor mount straps
Posted: Sun Dec 19, 2010 10:53 am
Lower motor mount strapsThis is a multi-part message in MIME format.________________________________________________________________________________Date: Sun, 19 Dec 2010 15:21:25 -0700Subject: Re: Pietenpol-List: Lower motor mount straps
Posted: Sun Dec 19, 2010 2:04 pm
Original Posted By: jimisown(at)aol.com
The plans and supplemental plans show 2 different full sized drawings forthe lower motor mount straps. Neither seems to fit the application well.It also appears to mount the inside straps you need to cut away a couple ofinches of the lower crosspiece on each end. Not real comfortable with that.Could others share how they dealt with this part of building?Thanks,JackJack Textor29 SW 58th DriveDes Moines, IA 50312www.textors.com________________________________________________________________________________Subject: Pietenpol-List: New to list
Posted: Sun Dec 19, 2010 3:26 pm
I'm new to the list and while I've been an A and P for 20+ years, I have never built my own plane nor am I a pilot (yet). Are there any builders in the Norfolk, Virginia area?Fr. Jim Lingenfelter________________________________________________________________________________
Posted: Sun Dec 19, 2010 3:53 pm
Original Posted By: Jack
Lower motor mount strapsI'm using the motor mounts designed for the GN 1. I'll send you copies of my drawings if you want them. I felt the same way you do about having to cut the cross pieces. My mounts are completely outside the wood structure. Chuck ----- Original Message -----
Posted: Sun Dec 19, 2010 4:08 pm
Original Posted By: Jim Boyer
Posted: Sun Dec 19, 2010 4:10 pm
Waiting for a flight, no plans in front of me so going from memory, but I'm pretty sure cutting a slot in the cross piece is just how you have to do it. That's how it is on ours, no issues. If I recall that's how most Piets are...Ryan Ryan Mueller-----Original Message-----
Posted: Sun Dec 19, 2010 4:25 pm
Let me be the first to welcome you to the Pietenpol list. You will find a greatbunch of builders and flyers here. Building can be very rewarding. Lots of experiencehere too. We range in age from 13 to somewhere around 80.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers doneusing Lycoming O-235Read this topic online here:
Posted: Sun Dec 19, 2010 5:11 pm
Original Posted By: "Jim Boyer"
Wish I had thought of that!!! Chuck----- Original Message -----
RE: Pietenpol-List: New to list
Posted: Sun Dec 19, 2010 6:47 pm
Hi Jim,I'm in Raleigh, NC - not too far away. My Pietenpol is based at SmithMountain Lake, VA (W91). Chuck Borsuk is also in the Raleigh area.Jack PhillipsNX899JP "Icarus Plummet"Raleigh, NC _____
