Pietenpol-List: Re: Wing Rib - Auto Cad - Careful what you get
Posted: Sun Jan 04, 1998 3:15 pm
Original Posted By: Bill Talbert
I noticed this, too. Does anyone have a more accurate one? Also, what is the status of whether or not we can make CAD drawings of the whole plans? > THIS IS JUST A QUICK NOTE ->> > Last month there was an AutoCad drawing of the wing rib put out> on this usenet and I have found it to be not per the pietenpol> prints which are given by Don Pietenpol. Some of the discrepancies> are:> > 1. Spacing between front and rear spar was not 27-3/4 inches.> I found it to be about 28-1/4.> 2. The last brace at the trailing edge was not from the upper> side of the rear spar to the lower capstrip at the trailing> edge. This is weaker support for the Aerodynamic forces if> it is backwards from the print.> > I did not check any further. > > I guess the term Caveat de-Emptor has a familiar tune. > > > > --> -----------------------------http://www.wrld.com/w3builderPietenpols, Electronic Music,Website Design, Stompilation________________________________________________________________________________
