Pietenpol-List: Re: Plans -Reply
Posted: Tue Jan 27, 1998 11:07 am
Original Posted By: William Conway
Ian, the Ford Escort is basically an unknown for me since I haven't flow ityet. I used the conversion kit made by Ed Lubitz, a Canadian airline pilot. It has a simple, cast iron reduction system 2.5-1. The engine conversionis mainly changes to the carb, removing emissions system, and shiftingthe location of the distributor. The engine is reversed with the flywheelforward. I have a full electrical system and somewhere between 70-80h.p. I've run the engine about four hours static (mounted on plane)without prop. It doesn't idle very well but from 2000 - 5000 rpms it runsvery well; this would be its normal operation range taxi/takeoff/climb. Igot the components second hand so don't know if they're currentlyavailable. The engine weighs about 270 pounds. I hope to have theplane in the air by April /May first. Ed apparently flew a Piet to Oshkoshin the late 80's with this engine conversion. I've not run into anyone withthis set up so have no other reports. My whole installation seems solidand I hope it will work well. Ask me in a few months. Bill ________________________________________________________________________________
