Pietenpol-List: WTB: A-65 around Texas/OK/NM/Ark
Posted: Mon Feb 16, 1998 1:31 pm
Original Posted By: Doug Hunt
Fellow Piet folks:My mechanic recently did a ring job/valve grind/conrod bearingjob on my A-65 and the engine is much happier now.However, it was decided that I should start looking for another A-65core for future use. The main thing I'm looking for is a good crankthat can still be ground or a freshly ground crank that hasn't beenabused. If I find a core I would really need to split the case tosee if there is anything usefull inside...Anybody have an A-65 around the Texas area?P.S. This will probably be the subject of a major overhall andconversion to A-75.Thanx,Kevin1982 Piet1956 Tri-Pacer________________________________________________________________________________
Pietenpol-List: Re: WTB: A-65 around Texas/OK/NM/Ark
Posted: Mon Feb 16, 1998 2:26 pm
Where are you located in Texas?Mike>Fellow Piet folks:>>My mechanic recently did a ring job/valve grind/conrod bearing>job on my A-65 and the engine is much happier now.>>However, it was decided that I should start looking for another A-65>core for future use. The main thing I'm looking for is a good crank>that can still be ground or a freshly ground crank that hasn't been>abused. If I find a core I would really need to split the case to>see if there is anything usefull inside...>>Anybody have an A-65 around the Texas area?>>P.S. This will probably be the subject of a major overhall and>conversion to A-75.>>Thanx,>Kevin>1982 Piet>1956 Tri-Pacer>>-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-* ring: 214.905.9299 fax: 214.905-1438 zap: mikek(at)intex.net web site: www.comedy-wire.com________________________________________________________________________________
