Pietenpol-List: Elevator thoughts
Posted: Mon Feb 23, 1998 6:51 am
Original Posted By: mikek(at)intex.net (Michael King)
Ted- You mentioned feeling like you might be running out ofelevator control in the flare. A few things came to mind......I was wondering what your empty weight might be, what distanceof elevator 'up' throw you have above neutral, and if you'veever calibrated your airspeed indicator by flying back and forthover some cross roads of a known distance w/ a stopwatch.When we had the 7AC Champ we found our airspeed was offand we were flying our approaches too slow. My partner/mechanicand all-round great guy Joe Tomasic put a small rubber grommetover the static line in front of those tiny holes. We kept movingthat grommet around slightly until the airspeed at cruise andapproach was just as good as we could get it and things mademore sense. One last thing: do you know what your CG is foryour most common loadings when flying ? All the best, Mike C. ________________________________________________________________________________
