Pietenpol-List: RE: aileron cables
Posted: Tue Mar 10, 1998 1:15 am
Original Posted By: stephen
Subject: Pietenpol-List: RE: aileron cables>>>On Tuesday, March 10, 1998 8:15 AM, Jim Sury [SMTP:jimsury(at)fbtc.net] wrote:>> I am in the process of hooking up my aileron cables and was wondering if>it>> is better to locate the turn buckles inside the wing and cockpit or is it>> ok to locate them at the aileron horns. I know that they would create>less>> drag inside the wing and cockpit. They sure would be easier to install>and>> adjust out on the wing. Any comments on this will be appreciated.> Another>> question I have is how much aileron travel is the correct amount? Thank>> jas>> jimsury(at)fbtc.net>>I quit worrying about drag the day I layed eyes on a photo of a piet. I>put a turnbuckle on top on on wing and on the bottom of the other, and two>in the cockpit. This allows me not only to set the ailerons neutral, bua>also correct tension on each cable, and allows me to center the stick.>>Stevee>________________________________________________________________________________
Pietenpol-List: aileron cables
Posted: Tue Mar 10, 1998 9:15 am
I am in the process of hooking up my aileron cables and was wondering if itis better to locate the turn buckles inside the wing and cockpit or is itok to locate them at the aileron horns. I know that they would create lessdrag inside the wing and cockpit. They sure would be easier to install andadjust out on the wing. Any comments on this will be appreciated. Anotherquestion I have is how much aileron travel is the correct amount? Thankjasjimsury(at)fbtc.net________________________________________________________________________________
Pietenpol-List: Re: aileron cables
Posted: Tue Mar 10, 1998 12:01 pm
I used one turnbuckle in the center section and 2 on the stick. Doug Hunt..-----Original Message-----
Posted: Tue Mar 10, 1998 1:22 pm
Original Posted By: clawler
On Tuesday, March 10, 1998 8:15 AM, Jim Sury [SMTP:jimsury(at)fbtc.net] wrote:> I am in the process of hooking up my aileron cables and was wondering if it> is better to locate the turn buckles inside the wing and cockpit or is it> ok to locate them at the aileron horns. I know that they would create less> drag inside the wing and cockpit. They sure would be easier to install and> adjust out on the wing. Any comments on this will be appreciated. Another> question I have is how much aileron travel is the correct amount? Thank> jas> jimsury(at)fbtc.netI quit worrying about drag the day I layed eyes on a photo of a piet. I put a turnbuckle on top on on wing and on the bottom of the other, and two in the cockpit. This allows me not only to set the ailerons neutral, bua also correct tension on each cable, and allows me to center the stick.Stevee________________________________________________________________________________
Posted: Tue Mar 10, 1998 9:45 pm
Original Posted By: LanhamOS
I'm no expert at all. Once somewhere a long time ago I saw a pietenpol withone aileron turnbuckel. It was on top of the wing exactly over the center. Iremember it because I thought at the time it was so strange,but maybe clever.Cheers Steve Yahn>I am in the process of hooking up my aileron cables and was wondering if it>is better to locate the turn buckles inside the wing and cockpit or is it>ok to locate them at the aileron horns. I know that they would create less>drag inside the wing and cockpit. They sure would be easier to install and>adjust out on the wing. Any comments on this will be appreciated. Another>question I have is how much aileron travel is the correct amount? Thank>jas>jimsury(at)fbtc.net>>________________________________________________________________________________
Posted: Mon Mar 16, 1998 9:28 pm
I just finished installing the aileron cables on my GN-1 and see that Ihave a small problem. Seems that when I deflect the ailerons fully thecables get loose. I was just wondering if any of you have experienced thesame thing. The ailerons horns are identical as they were shaped whilebeing bolted together. Is this the norm or what? Where might the problembe? If I tighten the cable with the ailerons fully deflected than thecables are too tight in the neutral position. Anybody have any suggestionsas to where I might look for the problem? Thanks jasjimsury(at)fbtc.net________________________________________________________________________________
Posted: Tue Mar 17, 1998 5:04 pm
Original Posted By: Jim Sury
Posted: Tue Mar 17, 1998 6:44 pm
Original Posted By: rrager(at)idir.net (Rick Rager)
>I just finished installing the aileron cables on my GN-1 and see that I>have a small problem. Seems that when I deflect the ailerons fully the>cables get loose. I was just wondering if any of you have experienced the>same thing. The ailerons horns are identical as they were shaped while>being bolted together. Is this the norm or what? Where might the problem>be? If I tighten the cable with the ailerons fully deflected than the>cables are too tight in the neutral position. Anybody have any suggestions>as to where I might look for the problem? Thanks >jas>jimsury(at)fbtc.net>>I am kind of having the same problem as you but I am installing theelevator cables, when I shove the stick full forward I get alot of slack inthe cables.I tried moving the belcrank up and down to see if that helped but it didntseem to make any difference. What I realize is that I will never deflect thestick to full travel under normal conditions. What I did was to nicopresstwo short cables to my down elevator cable and add a heavy tension springapprox 9" long between them. I then adjusted my cables so when I had fullup elevator the tension was correct and as I push forward stick the springpulls slack in the cable. In case the spring would ever break or come loosethe orig cable would still be intack, it would have some slack in it butyou still could fly it.Hope to be in your postion in riggin ailerons soon. I also have a questionon the elevator and rudder rigging? Is there any set degrees or any kind ofstops needed on the elevator or rudder.________________________________________________________________________________
Posted: Tue Mar 17, 1998 6:45 pm
>To: Pietenpol Discussion
Posted: Wed Mar 18, 1998 7:50 pm
The rudder is easy. You need stops to keep the rudder from banging intothe elevators. I set mine with 1 inch. clearance. The elevators are alittle harder. You need enough up elevator to flare at low speed. That youhave to figure out.I think I found out why my cables go slack at full aileron deflection.There is some difference in the distance between the pivot point of theaileron and the ends of the horns. Not a lot but it is there. Looks like Iwill be remaking the aileron horns. jas>>I just finished installing the aileron cables on my GN-1 and see that I>>have a small problem. Seems that when I deflect the ailerons fully the>>cables get loose. I was just wondering if any of you have experienced the>>same thing. The ailerons horns are identical as they were shaped while>>being bolted together. Is this the norm or what? Where might the problem>>be? If I tighten the cable with the ailerons fully deflected than the>>cables are too tight in the neutral position. Anybody have any suggestions>>as to where I might look for the problem? Thanks >>jas>>jimsury(at)fbtc.net>>>>I am kind of having the same problem as you but I am installing the>elevator cables, when I shove the stick full forward I get alot of slack in>the cables.>I tried moving the belcrank up and down to see if that helped but it didnt>seem to make any difference. What I realize is that I will never deflect the>stick to full travel under normal conditions. What I did was to nicopress>two short cables to my down elevator cable and add a heavy tension spring>approx 9" long between them. I then adjusted my cables so when I had full>up elevator the tension was correct and as I push forward stick the spring>pulls slack in the cable. In case the spring would ever break or come loose>the orig cable would still be intack, it would have some slack in it but>you still could fly it.>Hope to be in your postion in riggin ailerons soon. I also have a question>on the elevator and rudder rigging? Is there any set degrees or any kind of>stops needed on the elevator or rudder.>>jimsury(at)fbtc.net________________________________________________________________________________
Posted: Fri Jan 11, 2002 7:55 am
Original Posted By: "Doug Sheets"
John wrote:>I find that the two cables are contacting each other where they>cross each other in the cockpit.>Will appreciate your commentsThere's a fairly decent photo of this at http://www.flysquirrel.net/piets/piets3.html and is about the 7th photo down. I believe these are touching, but they have no rub protection and don't seem to be the worse for wear after (I believe) 700+ hours.Oscar ZunigaMedford, Oregonmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.netJoin the worlds largest e-mail service with MSN Hotmail. http://www.hotmail.com________________________________________________________________________________
Posted: Mon Jan 18, 2010 2:39 pm
RE: Pietenpol-List: aileron cables
Posted: Mon Jan 18, 2010 2:40 pm
I had the same problem Douwe. Congratulations! This just shows that youraileron horns are square with the torque tube (if they are square, thecables can't help but hit each other).Problem was solved by judicious application of a hammer to one side of theaileron horn on the torque tube. Just bend one of the horns (or both, butin opposite directions) enough to give some clearance between the cables.Depending on your enthusiasm with the hammer, you might have to enlarge theholes where they pass through the plywood under the instrument panel tomaintain clearance.Jack PhillipsNX899JPRakeigh, NC-----Original Message-----
Posted: Mon Jan 18, 2010 5:44 pm
Cool, Gardiner! Go for it and send pictures! Then fly off the hours so youcan take it to Sun 'n' Fun.Jack PhillipsNX899JPRaleigh, NC-----Original Message-----
Posted: Mon Jan 18, 2010 7:27 pm
Original Posted By: Mike King
Thanks Jack and Douwe, I'm just getting ready to weld mine. Will plan tooffset a bit.JackDSM________________________________________________________________________________Date: Tue, 19 Jan 2010 07:11:27 -0600 (GMT-06:00)
