Pietenpol-List: VolksPiets
Posted: Mon Apr 20, 1998 2:31 am
Original Posted By: TLC62770
I too have asked this dangerous question. The response in a nut-shell wouldappear to be one of horsepower and RPM. (Jump in guys!!)The most efficient props need get their horsepower at about 2400-2700 R.P.M.The Model A Ford engine not only sounds great, but delivers its H.P. in thisgolden R.P.M. range. Although the Corvair falls outside of this range andhas to turn a less efficient smaller prop, it has more horsepower which canmore than compensate.The VW would appear to fall into this category. You either have to use areduction gear/belt OR tweak the engine performance to get enough horsepowerto compensate like the Corvair.The only other "proplem" is that Pietenpol used only Model A' s and Corvairsto build his original aircraft. Many folks just don't want to mess with hissuccess! I never had the chance to know the man, but I somehow think thathe wouldn't have been so concerned about which brand of "motor" you use asmuch as JUST building a safe Piet...and Flying!Regards, and thanks Dom for the Subaru info!Jim-----Original Message-----
