Pietenpol-List: fuselage time -Reply
Posted: Wed Jun 10, 1998 11:23 am
Your intuition on the sides is correct. The FGM gives a good explanationof how to do the sides.The tailpost scarf can be done with a hand saw. Clamp the sides togetherand start sawing. When almost done, unclamp the sides and finish up with ahand plane.Hand sawing with the sides clamped together guarantees the correct scarfangle.Greg Cardinal>>> "Lee L. Schiek" 06/10/98 10:45am >>>Ribs & tail feathers done - need to move on to fuselage, so fromThe Stupid Question Dept: Do I layout & build sides flat and then"clamp & crank" them to fit top & bottom dimensions, or is their abetter way? Also, tailpost scarf has me a little confused......Low & Slow,Lee________________________________________________________________________________
