Pietenpol-List: New guy with fir/spruce question.
Posted: Wed Jul 08, 1998 11:27 pm
Subject: Pietenpol-List: New guy with fir/spruce question.>Hi Folks,>>I'm new around here, so get ready for a lot of questions. First of all, abig>"two thumbs up" to Steve Eldredge and Richard DeCosta for maitaining and>archiving this list. Both look like tremendous, invaluable resources.>>Next, a quick background check: I bought the "Improved Air Camper" plansfrom>Orrin Hoopman and joined the BPA nearly a decade ago, shortly after meeting>Dick Alkire and Howard Henderson at an airshow in Dayton, OH. I wasfinishing>college and starting grad school at the time (i.e., quite poor) so the woodand>tools I purchased for this project were diverted to a less ambitous wooden>boat. 5 boats later, I have more resources to draw from, and I have>enthusiastically returned to this project. I've been researching for a few>months now, I've acquired a 110 hp Corvair motor, and I've ripped andplaned>cap strips. Building rib jig this weekend.>>OK, let's start with materials. I have located a local source ofbreathtaking>Douglas Fir T&G deck planking that was recovered, unused, from an old>shipyard. Some planks are quarter sawn with hardly a single graindeviation>over 14' of 3/4" x 4" wood, all for about a buck/lineal foot. I've donesome>stress tests which show that it is abot 20% stronger than Sitka Spruce fromthe>same source, but I'm concerned about the added weight. I spoke recentlywith>Howard Henderson who says that he used primarily fir throughout his ship>(spruce tail to maintain CG), but he reduced most cross-sectionaldimensions by>25%. Seems to have worked out quite nicely.>>Questions:>Are there others out there who have done this?>How has the W&B turned out?>What do you think about laminating spars from this material (since they'rea>bit less than 4" across)?>If you approve of laminated Fir spars, would you reduce thickness from the>standard 3/4" spruce spar? (5/8" sounds thin to me).>Any references to documents with extensive comparisons of these materialsin>airframes?>>Thanks, more to come...>>Peter Frantz>________________________________________________________________________________
