Pietenpol-List: Engine Mount
Posted: Mon Aug 10, 1998 12:51 pm
My name is Sandy and I just recently purchased a Piet with a Franklin90HP. The mounting was done with EMT conduit frame bolted to thefirewall. The engine is placed about 15 to 18 inches from firewall toback of engine. I have a couple of questions. The thrust line on theengine appears to be prop down about 1" to 1.25". I notice in the plansthat for the "A" engine it show a nose low mounting. Would this applyfor all engines. Does anyone have information on mating a Franklin 90 toa Piet.My name is Sandy and I just recentlypurchased aPiet with a Franklin 90HP. The mounting was done with EMT conduit frameboltedto the firewall. The engine is placed about 15 to 18 inches fromfirewall toback of engine. I have a couple of questions. The thrust line on theengineappears to be prop down about 1 to 1.25. I notice in theplans thatfor the A engine it show a nose low mounting. Would thisapply forall engines. Does anyone have information on mating a Franklin 90 to aPiet.________________________________________________________________________________
Pietenpol-List: Re: Engine Mount
Posted: Mon Aug 10, 1998 7:04 pm
>My name is Sandy and I just recently purchased a Piet with a Franklin 90HP.>The mounting was done with EMT conduit frame bolted to the firewall. The>engine is placed about 15 to 18 inches from firewall to back of engine. I>have a couple of questions. The thrust line on the engine appears to beprop >down about 1" to 1.25". I notice in the plans that for the "A" engineit >show a nose low mounting. Would this apply for all engines. Does anyonehave >information on mating a Franklin 90 to a Piet. Interesting. I have a Piet with the same engine. I didn't build it andhaven't looked at the mounting and plans in much detail so I can't help youmuch on that. As on yours there is a lot of room behind the engine. Thismakes the cowling very long but hasn't seemed to cause any problem withflying characteristics. Franklins are very smooth running and the 90 Hpgives nice take off and climb performance (but doesn't help much in cruise!).Jim Skinner________________________________________________________________________________
Posted: Wed Jan 30, 2013 5:23 am
I'm finding the motor mount to be a challenge for sure. I checked out a lotof pictures for help so here are some to assist others challenged...JackDSM________________________________________________________________________________Subject: Pietenpol-List: Re: Engine Mount
Posted: Wed Jan 30, 2013 7:08 am
Jack,Nice work, as with most of your posts.>From what I see, it appears the frame is a weldment, which doesn't come apart... How will you remove your completed engine mount? Will it slide out?Please keep more pics coming.--------Tom KreinerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 30 Jan 2013 07:11:16 -0600 (GMT-06:00)
Re: Pietenpol-List: Re: Engine Mount
Posted: Wed Jan 30, 2013 7:26 am
Original Posted By: Jack
Hello Oscar,I too don't like what EAA national has been up to. I do however like what mostof the local EAA chapters are doing. I have been a tech counselor for closeto 20 years now. I do like doing that and I think that if we didn't self police,the accident statistics would reflect that. It is the main reason I am stilla member. I also learn a lot with every airplane visit I make. In fact,I probably learn more than the builder does. I usually only spend about ten minutesskimming through the magazine. Nothing very good in there for the lastfew years. Yes Oscar I agree with you and wouldn't bee a member except the Tech Counselorpart. Just my 3 cents,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Engine Mount
Re: Pietenpol-List: Engine Mount
Posted: Wed Jan 30, 2013 7:30 am
Tom excellent observation, I had not given it any thought! Duh...if it doesn'tslide out I will cut the uprights carefully so I can pass the jig on...Sent from my iPadJack TextorOn Jan 30, 2013, at 7:08 AM, "tkreiner" wrote:> > Jack,> > Nice work, as with most of your posts.> >> From what I see, it appears the frame is a weldment, which doesn't come apart... How will you remove your completed engine mount? Will it slide out?> > Please keep more pics coming.> > --------> Tom Kreiner> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 264#393264> > > > > > > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Engine Mount
Posted: Wed Jan 30, 2013 7:37 am
John I'm planning that it will need some tweaking to fit the mounts. Even witha jig my gear moved about a half inch. Instead of forcing the gear I plugged theexisting holes and moved the gear mount on the fuselage to match. Should havenot drilled the front mount holes...Sent from my iPadJack TextorOn Jan 30, 2013, at 7:11 AM, John Franklin wrote:> >> I'm finding the motor mount to be a challenge for sure. I checked out a lot>> of pictures for help so here are some to assist others challenged...>> Jack>> DSM> > Jack,> > I too am struggling with my engine mount. I started out with a jig and tackwelded the first set of tubes. I started having trouble with the bigger clusterwelds because I couldn't get enough heat on them. So, I removed the mountfrom the jig to weld them, thinking the jig was sinking away too much heat. WhenI tried to put it back on the jig, it didn't want to fit. After consultingwith another builder, I "coerced" the mount back on the jig with a rubber malletand now am planning on re-heating the clusters to relieve the stress. Ihope this works. I have one remaining tube to weld onto the mount and I am definitelygoing to leave it on the jig when I do that.> > Regards,> John F.> Prairie Aire 4TA0> GN-1 / Corvair 164CID> > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Re: Engine Mount
Posted: Wed Jan 30, 2013 7:45 am
Tom as I look closer I should be ok sliding it up. I will have to remember to weldthe bottom x braces out of the jig...thanks for the heads up!Sent from my iPadJack TextorOn Jan 30, 2013, at 7:08 AM, "tkreiner" wrote:> > Jack,> > Nice work, as with most of your posts.> >> From what I see, it appears the frame is a weldment, which doesn't come apart... How will you remove your completed engine mount? Will it slide out?> > Please keep more pics coming.> > --------> Tom Kreiner> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 264#393264> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Engine Mount
Posted: Wed Jan 30, 2013 8:11 am
Original Posted By: "Windstream Mail"
Jack,If I were modifying this jig, I'd get 4 plates which would be bolted to the uprights,matched drilled for AN5 bolts, maybe 3 to 4 inches apart prior to cuttingthe uprights. If the plates are suitably stamped or marked as to UP, or someway to identify where they go, the frame can then be bolted together, unbolted,etc., to remove the completed frames.My two cents worth...--------Tom KreinerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Engine Mount
Posted: Wed Jan 30, 2013 9:34 am
Looks very nice. Better than most I have seen. Jerry Prairie City, IA-----Original Message-----
Posted: Wed Jan 30, 2013 11:31 am
If this catches fire were in trouble!Sent from my iPadJack TextorOn Jan 30, 2013, at 10:35 AM, Ben Charvet wrote:> > On 1/30/2013 6:23 AM, Jack wrote:>> I'm finding the motor mount to be a challenge for sure. I checkedout a lot>> of pictures for help so here are some to assist others challenged...>> Jack>> DSM> Thats really a nice jig. Mine was made out of plywood and steel, and it wouldkeep catching fire. To let the weld properly cool, I'd have to blow out theflames.> > -- > Ben Charvet, PharmD> Staff Pharmacist> Parrish Medical center> > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Engine Mount
Posted: Wed Jan 30, 2013 11:32 am
Just want to make it the best possible for your expert welding!Sent from my iPadJack TextorOn Jan 30, 2013, at 9:34 AM, "JerryGrogan" wrote:> > Looks very nice. Better than most I have seen. > > Jerry > Prairie City, IA> > -----Original Message-----
Re: Pietenpol-List: Pitot Tube Bend
Posted: Wed Jan 30, 2013 11:37 am
Michael I wondered the same, hope to see some thoughts...Sent from my iPadJack TextorOn Jan 28, 2013, at 2:27 PM, Michael Perez wrote:> > Before installing the pitot tube to the wing, I am wondering if it would be worth bending the tube first. I have seen them both straight and bent and am curious if a bend would allow water to settle in on the bottom and allow "dry" air to flow into the indicator. (if getting cought in rain in flight) Perhaps in flight, the water will just get pushed in anyway. Anyone have issues with the straight tube pitots and water?> > Michael Perez> Pietenpol HINT Videos> Karetaker Aero> www.karetakeraero.com> > ============================================================================================================================================> ________________________________________________________________________________
Posted: Wed Jan 30, 2013 11:50 am
Original Posted By: "Ben Charvet"
Ben, I am getting ready to build my engine mount for the Corvair engine. I was going to build the jig out of 3/4 plywood with a thin sheet of galvanized steel covering the wood where the welding was to be done. Would this keep the flames down? Chuck----- Original Message -----
Posted: Wed Jan 30, 2013 12:04 pm
Posted: Wed Jan 30, 2013 1:50 pm
Mine's bent...no issues.Gary BootheNX308MBSent from my iPhoneOn Jan 30, 2013, at 9:37 AM, Jack wrote:> Michael I wondered the same, hope to see some thoughts...> > Sent from my iPad> Jack Textor> > On Jan 28, 2013, at 2:27 PM, Michael Perez wrote:> >> >> Before installing the pitot tube to the wing, I am wondering if it would be worth bending the tube first. I have seen them both straight and bent and am curious if a bend would allow water to settle in on the bottom and allow "dry" air to flow into the indicator. (if getting cought in rain in flight) Perhaps in flight, the water will just get pushed in anyway. Anyone have issues with the straight tube pitots and water?>> >> Michael Perez>> Pietenpol HINT Videos>> Karetaker Aero>> www.karetakeraero.com> > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> ________________________________________________________________________________Subject: Re: Pietenpol-List: Engine Mount
Posted: Wed Jan 30, 2013 1:54 pm
Original Posted By:> ----- Original Message ----- "Ben Charvet"
I like a good fire, now and then! My jig was all 2x4, merely holding 1/2" all-threadin place, while nuts and washers held the parts in place, and 100% sacrificial.Gary BootheNX308MBSent from my iPhoneOn Jan 30, 2013, at 9:50 AM, "C N Campbell" wrote:> > Ben, I am getting ready to build my engine mount for the Corvair engine. I wasgoing to build the jig out of 3/4 plywood with a thin sheet of galvanized steelcovering the wood where the welding was to be done. Would this keep the flamesdown? Chuck>
Posted: Wed Jan 30, 2013 2:05 pm
Subject: Re: Pietenpol-List: Pitot Tube Bend
Posted: Wed Jan 30, 2013 2:17 pm
30"+GarySent from my iPhoneOn Jan 30, 2013, at 12:05 PM, Ken Bickers wrote:> But Gary, does it ever rain in Cool California?> > On Wed, Jan 30, 2013 at 12:50 PM, Gary Boothe wrote:>> Mine's bent...no issues.>> >> Gary Boothe>> NX308MB>> >> Sent from my iPhone>> >> On Jan 30, 2013, at 9:37 AM, Jack wrote:>> >>> Michael I wondered the same, hope to see some thoughts...>>> >>> Sent from my iPad>>> Jack Textor>>> >>> On Jan 28, 2013, at 2:27 PM, Michael Perez wrote:>>> >>>> >>>> Before installing the pitot tube to the wing, I am wondering if it would be worth bending the tube first. I have seen them both straight and bent and am curious if a bend would allow water to settle in on the bottom and allow "dry" air to flow into the indicator. (if getting cought in rain in flight) Perhaps in flight, the water will just get pushed in anyway. Anyone have issues with the straight tube pitots and water?>>>> >>>> Michael Perez>>>> Pietenpol HINT Videos>>>> Karetaker Aero>>>> www.karetakeraero.com>>> >>> >>> >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>>> npol-List"">http://www.matronics.com/Navigator?Pietenpol-List>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>>> //forums.matronics.com>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>>> ot;">http://www.matronics.com/contribution>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>>> >> >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List>> tp://forums.matronics.com>> _blank">http://www.matronics.com/contribution>> > > > ============================================================================================================================================> ________________________________________________________________________________Subject: Re: Pietenpol-List: Pitot Tube Bend
Posted: Wed Jan 30, 2013 2:22 pm
Original Posted By: "dwilson"
I don't get the concern. I don't care how you design your pitot, on a Piet there will always be a point lower than the tube opening. Just cover it if you have a concern.Gary BootheNX308MBSent from my iPhoneOn Jan 30, 2013, at 12:05 PM, Ken Bickers wrote:> But Gary, does it ever rain in Cool California?> > On Wed, Jan 30, 2013 at 12:50 PM, Gary Boothe wrote:>> Mine's bent...no issues.>> >> Gary Boothe>> NX308MB>> >> Sent from my iPhone>> >> On Jan 30, 2013, at 9:37 AM, Jack wrote:>> >>> Michael I wondered the same, hope to see some thoughts...>>> >>> Sent from my iPad>>> Jack Textor>>> >>> On Jan 28, 2013, at 2:27 PM, Michael Perez wrote:>>> >>>> >>>> Before installing the pitot tube to the wing, I am wondering if it would be worth bending the tube first. I have seen them both straight and bent and am curious if a bend would allow water to settle in on the bottom and allow "dry" air to flow into the indicator. (if getting cought in rain in flight) Perhaps in flight, the water will just get pushed in anyway. Anyone have issues with the straight tube pitots and water?>>>> >>>> Michael Perez>>>> Pietenpol HINT Videos>>>> Karetaker Aero>>>> www.karetakeraero.com>>> >>> >>> >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>>> npol-List"">http://www.matronics.com/Navigator?Pietenpol-List>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>>> //forums.matronics.com>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>>> ot;">http://www.matronics.com/contribution>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>>> >> >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List>> tp://forums.matronics.com>> _blank">http://www.matronics.com/contribution>> > > > ============================================================================================================================================> ________________________________________________________________________________Subject: Pietenpol-List: Re: Engine Mount
Posted: Wed Jan 30, 2013 2:53 pm
Jack, Not only is your shop as clean as an operating room, you are a metal surgeonto boot. All looks very professional. DanRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Posted: Wed Jan 30, 2013 3:30 pm
Original Posted By: "John Franklin"
Thanks, John. I hadn 't even thought of that. Guess I'll take this up with my welder. He uses TIG which is not as hot as Oxy Acetylene----- Original Message -----
Posted: Wed Jan 30, 2013 3:38 pm
Did you, like John, have a problem with the heat causing the 1/2" threaded rod to wallow out the holes in the wood. I guess I could make mine out of 2X4 also. I was planning on 3/4" plywood -- in fact have already bought the plywood, but the 2X4 might absorb a little more heat. My welder uses TIG. I understand this is not as hot as Oxy Acetylene. Do you know if this is true? Gary, I was very impressed by the film clip of your airplane flying the first time. Congrats. Chuck----- Original Message -----
Posted: Wed Jan 30, 2013 3:48 pm
Hey, Guys, I would like to see some pictures of pitot tube installations. Are there any on West Coast Piet? C ----- Original Message -----
Posted: Wed Jan 30, 2013 3:59 pm
Original Posted By:> ----- Original Message ----- "Gary Boothe"
Thanks, Chuck! Yes, the burned, and I'm sure there was some 'wallering', but notenough of the 2x4 burned to be a problem.GarySent from my iPhoneOn Jan 30, 2013, at 1:38 PM, "C N Campbell" wrote:> > Did you, like John, have a problem with the heat causing the 1/2" threaded rodto wallow out the holes in the wood. I guess I could make mine out of 2X4 also.I was planning on 3/4" plywood -- in fact have already bought the plywood,but the 2X4 might absorb a little more heat. My welder uses TIG. I understandthis is not as hot as Oxy Acetylene. Do you know if this is true? Gary,I was very impressed by the film clip of your airplane flying the first time.Congrats. Chuck>
Posted: Wed Jan 30, 2013 4:13 pm
Original Posted By:> ----- Original Message ----- "John Franklin"
In retrospect I maybe should not have painted mine...Sent from my iPadJack TextorOn Jan 30, 2013, at 3:30 PM, "C N Campbell" wrote:> > Thanks, John. I hadn 't even thought of that. Guess I'll take this up withmy welder. He uses TIG which is not as hot as Oxy Acetylene
Posted: Wed Jan 30, 2013 8:22 pm
That's ok Jack the paint will burn off when I weld it. Or you could alwaysjust us the jig as your engine mount. A little heavy though.Jerry-----Original Message-----
Pietenpol-List: Re: Pitot Tube Bend
Posted: Wed Jan 30, 2013 8:26 pm
When I installed my pitot tube in the wing I mounted a 1/4" ferule fitting withthe end flush with the bottom fabric. and I pressed it up enough to screw thenut on tight and have a removeable tube bent forwarded so if it ever gets damagedor I want to just take it off to prevent someone walking into it I can. sofar no problems but I can see vibration could loosen it. I silver soldered aflange to it and bolted it to the spar so it's solid and stays put when tightening.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: Wedgie
Posted: Wed Jan 30, 2013 9:49 pm
Hmmm.....how many things could you do withthis?http://www.leevalley.com/en/garden/page ... ___Subject: Pietenpol-List: Re: Wedgie
Posted: Thu Jan 31, 2013 8:13 am
I supply our guys here at Los Angeles Fire Department with these. We use themto help break into locked cars. Part of what we call a lock out kit. Just slipit between the glass and door, pump it up and then you have easy access forusing a slimjim to unlock the door. They work great. Useless fun fact #1 for the day,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
