Pietenpol-List: Drain Holes
Posted: Tue Sep 15, 1998 1:34 pm
Original Posted By: fishin
>Thanks all for your input, you convinced me to go ahead with the fairing>strip(s).Having a place for condensation to collect away from the airframeJoe/Group.....On the cockpit floor plywood where you have thosethree 3/16" holes just ahead of each, equally spaced left to right to allowfor wet feet, snow, rain, etc, (pop) to drain out of the belly. Then I put a few drain grommets in the belly fabric to suck that moisture out.Seaplane grommets would have been fancy here too. For those with nofabric on the belly these holes will help keep the floor dry too...Mike C. ________________________________________________________________________________
