Pietenpol-List: What Glue for ribs?
Posted: Mon Oct 12, 1998 10:32 am
Original Posted By: Ogden, Lexie
Hello everyone. I have been lurking out here for a few months enjoyingall the discussion. Love the Piet but after much thought have started tobuild a Hatz. My question is which kind of glue do you guys like best forrib construction?My rib jig is built with clamps that can apply considerable pressure tothe joints while drying. I hope not to have to leave the ribs in the jig toolong as I will try to build them all during a two week vacation. Also, withclamps to apply pressure to the joints I think I can forget about usingnails, am I right?-----Original Message-----
Pietenpol-List: Re: What Glue for ribs?
Posted: Tue Oct 13, 1998 4:14 am
Original Posted By:>> mikec(at)microlandusa.com (Mike Cunningham)
Subject: Pietenpol-List: Re: What Glue for ribs?>>> Subj: What Glue for ribs?>> Date: 98-10-12 11:11:52 EDT
Posted: Tue Oct 13, 1998 9:09 am
Original Posted By:> mikec(at)microlandusa.com (Mike Cunningham)
> Subj: What Glue for ribs?> Date: 98-10-12 11:11:52 EDT
Posted: Tue Oct 13, 1998 9:26 am
Original Posted By: Leo Powning
Hi Guys, Am building a long-fuse Piet and using T-88. This glue really does not needhigh pressure clamps, and on a flat surface does not need nails or clamps of anykind. Some folks worry about a slight surface stickiness when extremely hot,after fully curing, as inside the wing on a hot day.. In speaking with themanufacturer and a couple of old time builders who use T-88, this is a side effectof the non-brittle long life of this product. For your own peace of mind, wouldstrongly suggest that you glue up 3-4 pieces with different intersecting faces,let fully cure, set out in the hot sun and then self test them to destruction.Aswith all of these resin type products, it is extraordinarily important that mixingratios be properly observed, and that the mixing is thorough.Warren________________________________________________________________________________
Posted: Tue Oct 13, 1998 10:08 am
I used T-88 to build my all-wood Minimax. Its structure and loads are similiarto the Piet. I've flown many hours in the MiniMax. Some of those hours have beenin rough air when I would rather have been on the ground but I've never hada joint failure. I think the T-88 instructions call for only light pressure whenglueing so you won't need those clamps for the ribs if you use T-88. Staplesmay be better.Safe flying,Leo --On Tue, 13 Oct 1998 07:26:33 Warren D. Shoun wrote:>Hi Guys,> Am building a long-fuse Piet and using T-88. This glue really does not need>high pressure clamps, and on a flat surface does not need nails or clamps of any>kind. Some folks worry about a slight surface stickiness when extremely hot,>after fully curing, as inside the wing on a hot day.. In speaking with the>manufacturer and a couple of old time builders who use T-88, this is a side effect>of the non-brittle long life of this product. For your own peace of mind, would>strongly suggest that you glue up 3-4 pieces with different intersecting faces,>let fully cure, set out in the hot sun and then self test them to destruction.As>with all of these resin type products, it is extraordinarily important that mixing>ratios be properly observed, and that the mixing is thorough.>Warren>>-----== Sent via Deja News, The Discussion Network ==-----http://www.dejanews.com/ Easy access to 50,000+ discussion forums________________________________________________________________________________
Posted: Tue Oct 13, 1998 10:39 am
>I used T-88 to build my all-wood Minimax. I did the same as Leo....all T-88 and all glue joint tests broke thewood....even on some fairly poor joints. I hit some incredible turbulencenear Chicago enroute to Oshkosh too. (but severe clear otherwise).MC________________________________________________________________________________
Posted: Tue Oct 13, 1998 3:47 pm
Original Posted By: Richard Lamb
Hey, guys, I use Titebond II from the hardware store. It was recommendedat Oshkosh in one of the building sessions. >>> "David B. Schober" 10/13 2:53 PM >>>I don't have anything against epoxy type glues for wood but the wings onmyHoward are 55 years old and the Resorcinol joints are still holding up ona4500 lb airplane with a 270 mph red line. I'd like to see what the T88lookslike in 55 years!David SchoberMichael D Cuy wrote:> >I used T-88 to build my all-wood Minimax.>> I did the same as Leo....all T-88 and all glue joint tests broke the> wood....even on some fairly poor joints. I hit some incredibleturbulence> near Chicago enroute to Oshkosh too. (but severe clear otherwise).> MC--**David B.Schober, CPEInstructor, Aviation MaintenanceFairmont State CollegeNational Aerospace Education CenterRt. 3 Box 13Bridgeport, WV 26330-9503(304) 842-8300________________________________________________________________________________
Posted: Tue Oct 13, 1998 3:53 pm
Original Posted By: William Conway
I don't have anything against epoxy type glues for wood but the wings on myHoward are 55 years old and the Resorcinol joints are still holding up on a4500 lb airplane with a 270 mph red line. I'd like to see what the T88 lookslike in 55 years!David SchoberMichael D Cuy wrote:> >I used T-88 to build my all-wood Minimax.>> I did the same as Leo....all T-88 and all glue joint tests broke the> wood....even on some fairly poor joints. I hit some incredible turbulence> near Chicago enroute to Oshkosh too. (but severe clear otherwise).> MC--David B.Schober, CPEInstructor, Aviation MaintenanceFairmont State CollegeNational Aerospace Education CenterRt. 3 Box 13Bridgeport, WV 26330-9503(304) 842-8300________________________________________________________________________________
Posted: Wed Oct 14, 1998 10:12 am
Original Posted By: Hatz630(at)aol.com
Hey Scott,The rib jig I have in mind will only handle one rib at a time. This will besomewhat of a hinderance as I hope to build the ribs in a matter of weeks(as opposed to months). Have you seen a Jig for multiple ribs?T88 looks good to me so far, seems like it must be a fairly standardtwo part epoxy like I have used for years in RC model construction.It should be pretty easy to work with.-----Original Message-----
