Pietenpol-List: continental eng.
Posted: Fri Jan 22, 1999 1:13 am
Original Posted By: "Mr. Carmen A. Natalie"
Subject: Pietenpol-List: continental eng.>to anyone who can help>My name is Henry Williams , member of BPA(my e-adress is borodent(at)AOL.com),am>just starting a piet with a continental engine and I have a few questions>>1) I have piet plans but I am not sure if they are the long body. What is>the length of the long body ( firewall to tail end)>2) in using a lightweight continental engine, builders now add 6 or so>inches to the length of the long body. Correct??>3) What is the optimum position for the center of balance ( I know itsnot>to be over 20 inch past the leading edge - but what would be a perfect>position)?( say 18 in , 16 in past leading edge?)>4) What is the weight of the 65hp, the 85hp, the 100hp continentalengins?>5) Is there a source where I can look up such engine specs?>6) Does anyone have an e-mail (or other) adress for Bill Rewey he isalso>interested in a large pietHi Hank:I will try to help you, but I do not have some specific info on hand.1. The long fuselage prints were made by Vi Kapler to accommadate thecorvair engine. I do not have the precise figure, but I think it is 19 feetsomething. The extra length was added in the cockpit aera.2. That is one method. Another is to move the wing back.( as I did. )I knowof a Piet that has added lead weights to the motor mount.3. The CG of the Piet has been discussed for as long as I can remember. Itis my impression that most Piets are flying near 20 inches. Not to becontentious, but I believe that is a tail heavy condition. In my opinion theideal is between 14.5 & 18 inches. ( rough test, lift the tail to straight &level, let go. the aircraft should teeter. That's good ) 4. rough figure. add 100 lbs. 65=165. 85 = 185 plus. 0-200 minus altenator& starter about 200 lbs, with accessories about 225 lbs.( I fly with a0-200) The ford engine weighs about 240 lbs with the Al head minus the water5. the data can be found in the repair manuals.6. Can't help there.I don't mean to go on here but, if I were to do it again & wanted a C65Piet, I would build a Greiga. It was designed for the engine.Mike B ( Piet N 687MB )________________________________________________________________________________
Posted: Fri Jan 22, 1999 9:08 pm
Original Posted By: Hatz630(at)aol.com
to anyone who can helpMy name is Henry Williams , member of BPA(my e-adress is borodent(at)AOL.com), amjust starting a piet with a continental engine and I have a few questions 1) I have piet plans but I am not sure if they are the long body. What isthe length of the long body ( firewall to tail end)2) in using a lightweight continental engine, builders now add 6 or soinches to the length of the long body. Correct??3) What is the optimum position for the center of balance ( I know its notto be over 20 inch past the leading edge - but what would be a perfectposition)?( say 18 in , 16 in past leading edge?)4) What is the weight of the 65hp, the 85hp, the 100hp continental engins?5) Is there a source where I can look up such engine specs?6) Does anyone have an e-mail (or other) adress for Bill Rewey he is alsointerested in a large piet________________________________________________________________________________
Pietenpol-List: Re: continental eng.
Posted: Sat Jan 23, 1999 5:24 pm
Original Posted By: Borodent(at)aol.com
-----Original Message-----
Posted: Sat Jan 23, 1999 7:49 pm
Original Posted By: Michael Hinchman
>to anyone who can help>My name is Henry Williams , member of BPA(my e-adress is borodent(at)AOL.com), am>just starting a piet with a continental engine and I have a few questions >>1) I have piet plans but I am not sure if they are the long body. What is>the length of the long body ( firewall to tail end)>2) in using a lightweight continental engine, builders now add 6 or so>inches to the length of the long body. Correct??>3) What is the optimum position for the center of balance ( I know its not>to be over 20 inch past the leading edge - but what would be a perfect>position)?( say 18 in , 16 in past leading edge?)>4) What is the weight of the 65hp, the 85hp, the 100hp continental engins?>5) Is there a source where I can look up such engine specs?>6) Does anyone have an e-mail (or other) adress for Bill Rewey he is also>interested in a large piet>Why not try the Grega GN-1? It is designed for the Cont. a-65 thru o-200and is very similar to the piet.________________________________________________________________________________
Posted: Sun Jan 24, 1999 12:30 am
Original Posted By: andy picklesimer
to Mike Brusilow from Henry WilliamsThanks for ther info, I appreciate it. I think I and my son saw you lastsummer at Chapman field - but we didnt get to say hello________________________________________________________________________________
