Pietenpol-List: cont. 65 ground power unit
Posted: Wed Mar 10, 1999 6:30 pm
Original Posted By: Seibert
Hello,I would like to ask if anyone has had experience using the continental 65from a WWII surplus ground pwer unit. We found a vey affordable one and alllooks very good. I have head the front bearing might not be the same as on anaircraft.Any input would be appreciated.Thank youMike JohnstonPlainview mn________________________________________________________________________________
Pietenpol-List: Re: cont. 65 ground power unit
Posted: Thu Mar 11, 1999 12:35 am
Original Posted By: Mpj01(at)aol.com
I have never seen one but I have heard that the Continental GPU's had a castiron crankshaft.If the engine is assembled, there is probably no way to tell by visualinspection. There is no reason why a cast iron crank can't be used, its just not going tobe quite as strong as a forged steel one.Good luck,Bob Seibert________________________________________________________________________________
Posted: Thu Mar 11, 1999 6:24 am
Original Posted By: Wkoucky(at)aol.com
Thanks Bob, We have the case apart and everything mics out to within factory specs. Onequestion I do have is about the front bearing. And I have a few mechanics Ican ask about the cast crankshaft.Thanks againMike________________________________________________________________________________
