Pietenpol-List: tail wheel
Posted: Wed Mar 24, 1999 9:06 pm
Original Posted By: Wayne and Kathy
Looks like I need to replace the tailwheel on my Horizon2. It's roughly the same weight as a Piet. Anybody know of a good source?Dean Dayton - deandayton(at)hotmail.com________________________________________________________________________________
Pietenpol-List: Re: tail wheel
Posted: Wed Mar 24, 1999 11:07 pm
Dean Dayton wrote:> > Looks like I need to replace the tailwheel on my Horizon2. It's roughly> the same weight as a Piet. Anybody know of a good source?> > Dean Dayton - deandayton(at)hotmail.com> Use the castors that are available at industial and auto supply houses.they have sealed bearings, come in an infinite number of sizes. Bestpart is that they are cheap.Wayne Tokarz________________________________________________________________________________
Posted: Thu Mar 25, 1999 9:29 am
>Looks like I need to replace the tailwheel on my Horizon2. It's roughly >the same weight as a Piet. Anybody know of a good source?>You just found the PERFECT excuse to tell your wife you "need" to go to Sun& Fun or to Oshkosh to the flea market. :-) :-)SaludosGary Gower________________________________________________________________________________
Posted: Thu Jun 24, 1999 7:08 pm
Original Posted By: oil can
I'm looking at the AC spruce catalog,,,at tailwheels, and am not so sure which one I should buy for my super ace.Gross wt 1100 lbsI'd like one that is steerable, and also a spring to go with it.Page 206 has one that has a 4" wheel, options are for a 20, or 45 degree spring angle.Also page 209 there are some others. I preferr a light one if possible to keep weight out of the tail.Does any one have any suggestions ?________________________________________________________________________________
Posted: Thu Jun 24, 1999 7:51 pm
Original Posted By: bholbrook
Im building a piet and have about 1300 hours in a Maule. Save wt. but without a doubt get one that is steerable.Tom________________________________________________________________________________
Re: Pietenpol-List: tail wheel
Posted: Sun Apr 15, 2001 8:42 am
Subject: Re: Pietenpol-List: tail wheelIn a message dated 4/14/01 11:34:44 PM Pacific Daylight Time, javcr(at)yahoo.com writes:> Hi friends> Well,now i have the main landing gear for my Piet> finished, i start to make the tail wheel.> When i looking for the tail wheel, and i see many> options (fixed wheel, steering wheel, full swibel> wheel, etc) so what kind of tail wheel are you using?> or any suggestion?> all comments will be good.> By the way, anyone knows where i can find the> Aircamper Sim for Flight Simulator?> Thanks for your comments.> Javier Cruz> > > I do not use a tail wheel on mine; just a skid, per the plans. It is so easy to handle. Doug Bryant Wichita Ks________________________________________________________________________________
Posted: Fri Apr 21, 2006 1:47 pm
Original Posted By: "Arden Adamson"
RE: Pietenpol-List: tail wheel
Posted: Fri Apr 21, 2006 1:48 pm
Posted: Fri Apr 21, 2006 2:17 pm
Arden,Can't answer all your questions but here is what I used (AS&S Partnumbers)06-01615 , MATCO SOLID RUBBER , ( 5 Lbs)06-14500 , TAILWHEEL LEAF SPRING # 4 , (1 3/4 Lbs)Works for me.Hans________________________________________________________________________________Date: Fri, 21 Apr 2006 15:18:14 -0400
RE: Pietenpol-List: RIBS
Posted: Fri Apr 21, 2006 2:40 pm
Posted: Tue Aug 12, 2008 2:02 pm
Has anyone figured the weight of a standard leaf spring type tail wheel as compared to aPiet style tail skid converted to a tail wheel. I know there are many variations but I'm trying to decide if I should keep my current leaf spring or build a the original style. I need to improve my CG picture.Marc_________________________________________________________________Reveal your inner athlete and share it with friends on Windows Live.http://revealyourinnerathlete.windowsli ... ___Subject: RE: Pietenpol-List: tail wheelDate: Tue, 12 Aug 2008 15:10:18 -0400
Posted: Tue Aug 12, 2008 2:10 pm
Original Posted By: Jack.Phillips(at)cardinalhealth.com
Pietenpol-List: Re: From print to jig...how?
Posted: Tue Aug 12, 2008 3:59 pm
Mike et al:Regarding the suggestion that you have a copy of your rib drawing made at Kinko'sand having it laminated sounds like a great idea. However, let me tell youwhat can happen if you do.I lofted, very carefully, the GA30U-612 airfoil and took it to a professional engineeringfirm to have a few copies made. I told them that it must be an exactcopy since it would be used on a building jig and the spar locations must beon the mark. I went to pick up the copies and laid out the copy over the original.Registering the leading edge on both and moving left to right, I foundthat within about 14 inches the copy started to stray from the original. betweenthe spar locations the copy was off by a quarter inch. I called for themanager who said he would do the prints on another digital printer and it shouldbe fine.They did it again and once again we checked for accuracy. It was better this timebut the spar locations were still off by one eighth of an inch.I then decided that I would try Kinko's and they assured me they could make anexact copy. We tried it and it was way worse than the engineering blueprint company.It would not be such a big deal if it were not for the spar locations. I finallydecided to just use the original under thin clear plastic and am taking verygood care of the jig so as to not harm my original. If you decide to try the Kinko's copy routine, just be sure to put the originaland the print on a light table to check for accuracy.Another suggestion would be to simply lay down a bunch of carbon paper on the jigboard and trace the outline and also use a straight edge for the intercostalsand spar locations. Have fun.Bob--------Robert Butsch EAA 66532Pietenpol NX45BB (Alpha stage)In Indy INRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 12 Aug 2008 20:13:12 -0500
Posted: Wed Aug 13, 2008 6:53 am
Posted: Wed Aug 13, 2008 7:17 am
Original Posted By: charles loomis
> Pietenpol-List: What set of plans do I use??
Posted: Wed Aug 13, 2008 7:34 am
Posted: Tue Aug 19, 2008 5:44 pm
I weighed the tail wheel that came with my plane and it came to 10.25 lbs.I've been thinking about building a new one more like the original design.In the interest of keeping things light I was thinking about using a bungieinstead of the coil spring normally used. Attached is a crude picture of what I have in mind.I know the is dangerously close to an 'improvement' but what do you think?The bungie would be attached to the tail post with a turn buckle for adjustment. If the picture doesn't come through here is a link. http://picasaweb.google.com/sandy.n.mar ... 0898Thanks for your thoughts.Marc_________________________________________________________________Get thousands of games on your PC=2C your mobile phone=2C and the web with Windows=AE.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
Re: Pietenpol-List: tail wheel
Posted: Tue Aug 19, 2008 7:45 pm
Original Posted By: "Chet's Mail"
Subject: Re: Pietenpol-List: tail wheelMarc,In my opinion, 10 lbs is unacceptable. My tail wheel complete is half that weight. Five extra lbs. is a huge amount way back on the tail on an airplane that is already tail heavy to begin with. Please reconsider. Dan HelsperPoplar Grove, IL.**************It's only a deal if it's where you want to go. Find your travel deal here. (http://information.travel.aol.com/deals ... 0000000047)________________________________________________________________________________
Posted: Tue Aug 19, 2008 8:13 pm
Original Posted By: Marc Davis
Marc,I like the idea, do you have any plans to support the attaching point for the turn buckle?NX920Y flying well in MO with no heat problem anymore.Chet________________________________________________________________________________
Posted: Tue Aug 19, 2008 11:30 pm
Posted: Wed Aug 20, 2008 1:49 am
Bob Siebert did.http://westcoastpiet.com/images/Bob%20S ... 4.jpgChris TracySacramento, CaWebsite at http://www.WestCoastPiet.com----- Original Message -----
RE: Pietenpol-List: No clamps on ribs?
Posted: Wed Aug 20, 2008 6:00 am
Get some coated nails, a comfortable sized long nosed pliers, a good heavy headed small hammer and forget about clamps. Nathan and LeviIt's only a deal if it's where you want to go. Find your travel deal here.=0A=0A=0A ________________________________________________________________________________Subject: RE: Pietenpol-List: No clamps on ribs?Date: Wed, 20 Aug 2008 14:24:38 -0400
Re: Pietenpol-List: No clamps on ribs?
Get some coated nails, a comfortable sized long nosed pliers, a goodheavy headed small hammer and forget about clamps. Nathan and Levi _____ It's only a deal if it's where you want to go. Find your travel dealhere =2E_________________________________________________This message is for the designated recipient only and may contain privileged, proprietaryor otherwise private information. If you have received it in error, please notify the senderimmediately and delete the original. Any other use of the email by you is prohibited.Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese________________________________________________________________________________Date: Wed, 20 Aug 2008 13:58:58 -0500
RE: Pietenpol-List: tail wheel
Posted: Wed Aug 20, 2008 10:34 am
Posted: Wed Aug 20, 2008 10:57 am
Posted: Wed Aug 20, 2008 11:00 am
Original Posted By: "Dave Abramson"
Subject: Re: Pietenpol-List: No clamps on ribs?Get some coated nails, a comfortable sized long nosed pliers, a good heavy headed small hammer and forget about clamps. Nathan and Levi**************It's only a deal if it's where you want to go. Find your travel deal here. (http://information.travel.aol.com/deals ... 0000000047)________________________________________________________________________________
Posted: Wed Aug 20, 2008 12:00 pm
Remember, you want ALL the ribs identical!!! Use blocks over rib dwg. tohold all the wood. I even cut 2 pieces of my spar and put them on my ribprint. Then used the glue coated nails from ACS, small spring loaded needlenose pliers. and small hammer and nailed the gussets down. Let dry overnight.... then do other side. 1 rib per day.......... got-em done in notime.dave -----Original Message-----
Re: Pietenpol-List: Re: From print to jig...how?
Posted: Wed Aug 20, 2008 12:15 pm
Original Posted By: "JERRY GROGAN"
Subject: Re: Pietenpol-List: Re: From print to jig...how?Go raid your wife's dressmaking supplies, you are looking for a "tick wheel" its a little handle with a thin wheel on it with notches, it is used for transferring a dress pattern to material, we use colored wax transfer papers between the patterns and the cloth and trace with the tick wheel, it leaves colored dotted lines on the cloth.Use carbon paper instead. Any fabric store should sell tick wheels for less the $2.Regards, Chrissi (fabricating our Cozy engine cowls now)CG Products, Custom Aircraft Hardwarewww.CozyGirrrl.com Cozy Mk-IV RG 13B-turboPlans #957 Chapter? big pieces done, details, details=============================**************It's only a deal if it's where you want to go. Find your travel deal here. (http://information.travel.aol.com/deals ... 0000000047)________________________________________________________________________________
Posted: Wed Aug 20, 2008 1:16 pm
Original Posted By: Jack T. Textor
The clamps that Jack used work good if the ply pcs are made a little big so you can route off the excess. Because the Plywood can move around a little from the pressure from the clamp if the clamp is not on straight. But you can glue two sides at once. When we build ribs we do one side at a time and use 2 pound weights on each pc of ply wood. Its about the right amount of pressure. You still have to make the ply pcs a little big on the outside of the rib so you can route them off for a very nice finished product.Jerry GroganSky Classic Aircraft ----- Original Message -----
Posted: Wed Aug 20, 2008 1:29 pm
Posted: Wed Aug 20, 2008 1:40 pm
Posted: Wed Aug 20, 2008 2:33 pm
Original Posted By: "walt"
Posted: Wed Aug 20, 2008 3:34 pm
Original Posted By: TOM STINEMETZE
It has been mentioned before, but probably bears repeating. What I used was lightweight staples. Buy a light weight staple gun and use either 1/4" staples (on1/16" gussets) or 3/16" on thicker gussets. After the adhesive cures, use smallend nippers to grip and remove the staples. I also used aircraft nails andnailing strips on thicker plywood surfaces such as the fuselage sides. Onceyou get a system down using the hand staple gun works real well. I think I pickedup my gun at Home Depot for less than $10 and 1,000 staples only costs a coupleof bucks.Rick SchreiberValparaiso, IN----- Original Message -----
Posted: Mon Aug 25, 2008 12:45 pm
Original Posted By: CozyGirrrl(at)aol.com
Dan,Apparently I missed earlier discussion of your tailwheel. Would you please tell me what you have (off line)?Allan MacklemAWMacklem(at)cox.net________________________________________________________________________________
> Re: Pietenpol-List: What set of plans do I use??
Posted: Fri Apr 28, 2017 9:33 pm
Original Posted By:> "charles loomis"
> "gcardinal" > > Plans can be ordered from the Pietenpol family at:> http://www.pressenter.com/~apietenp/> > Articles on built up spars can be found in the construction> section of:> www.westcoastpiet.com> > Don't downsize the rib capstrips. You won't save> enough weight to make a > difference.> Roman Bukolt can comment on the steel tube fuselage.> > Where are you located Charley? You might have a Pietenpol> close by that you > can look at.> > Greg Cardinal> Minneapolis> > ----- Original Message -----
From: HelsperSew(at)aol.comDate: Tue=2C 19 Aug 2008 20:45:30 -0400 Re:
Dan I think you misread my post. I agree that 10.25 lbs is too heavy. This is what the plane came with. I looking for a better solution.The attached photo is one idea I'm considering to make it lighter.I like the look of your tail wheel.I was thinking that if you could replace the spring with a bungee it would be lighter still.Thanks for the info about the weight of your solution.Marc Pietenpol-List: tail wheelTo: pietenpol-list(at)matronics.comMarc=2CIn my opinion=2C 10 lbs is unacceptable. My tail wheel complete is half that weight. Five extra lbs. is a huge amount way back on the tail on an airplane that is already tail heavy to begin with. Please reconsider. Dan HelsperPoplar Grove=2C IL.It's only a deal if it's where you want to go. Find your travel deal here._________________________________________________________________Be the filmmaker you always wanted to be=97learn how to burn a DVD with Windows=AE.________________________________________________________________________________Date: Tue, 19 Aug 2008 22:08:20 -0500
