Pietenpol-List: Re: Welders; one man's opinion
Posted: Sun Apr 04, 1999 10:02 pm
Mike;Thanks for the quick response. I was aware of the heat zoneand considering the wall thickness involved did not think itwas a issue. I also do not think there are any criticalwelded pieces in the wood frame. Several are formed, thewelding tends to be on the landing gear and tail wheel as Irecall. As I recall, 4130 (Chrome Molly as we called it)tends to work harden, I will pull out my reference books andreview. When you say "gas outfit", are you talking stick orbrazing? Sounds like brazing from the "dying skill" remarkas I agree. My understanding of of stick versus wire feedis with stick you will have to go small diameter due to wallthickness, as a result your stick are shorter and you haveto feed the stringer more. This causes the work surface tohave more "heat /cool" cycles. With wire you tend to havecontinuous heat, the heat spreads over the area more andless stress. Sounds like we are entering the "everyone hasa bellybutton..." (or pick your orifice) arena. I amafraid there will be as many experts on one side versus theother. Personally, if I see a piece is critical from astructural point of view, I will have NDE performed on it.I do not wish to be falling from the sky thinking "... thatwas too much porosity" or " ...t I should make a secondpass"Thanks for your comments, I realize it's my decision and Iappreciate all the information, it gives me more to digest.Bill________________________________________________________________________________
