Pietenpol-List: Covers
Posted: Tue Apr 06, 1999 8:18 am
Original Posted By: Les Lampman
Hi Tom,The covers were put on last night just before our meeting. It was a littletoo cool for the dope however. I put some heat on in the hanger but may nothave been enough. Then when I finished I had to put it outside in the cold.The right side went on okay, but the left side had a little interferencewith the rib underneath. It just would not seat square on the fabric. I leftit as it was and covered it with fabric and dope. I hope it holds okay.I would recommend the flange to be another 1/4 of an inch, so it can have alittle more surface area for better adhesion. I would also make the curvedopening a little higher (about another 1/4 to 3/8 of an inch), this willallow you to better cover the hole toward the closed end and still clear thewire at the opening.Two snags to go. Thanks again for the covers.Regards,Domenic________________________________________________________________________________
