Pietenpol-List: DuPont 222S Sealer
Posted: Sun Apr 11, 1999 8:02 pm
Original Posted By: "BELLISSIMO, DOMENIC"
Subject: Pietenpol-List: DuPont 222S Sealer>The MEK (methyl ethel kytone) solvent found in most>aircraft finishing systems will attack regular varnish and >primers (zinc chromate, automotive, etc..unless 2 part)>however there is a way around this. My entire Piet was>varnished in Helmsman polyurethane by Minwax and left to>cure for about 2 months. The metal parts were all primed>in spray can zinc chromate and left to cure. All the wood and>metal parts were then sprayed with a light coating of DuPont>222S sealer it's called from the automotive paint store.>That sealed the parts against attack from MEK. This is how>the older wise owls out at our local strip do it.>The advantage with the two part systems though is you don't have>to wait for cure times. >>Mike C. >>________________________________________________________________________________
